Sony Bravia TV not seeing UMS server
Re: Sony Bravia TV not seeing UMS server
Thx, NeilNeil wrote:attached are the debug files
- uncheck 'HTTP Engine V2' in 'General Configuration' tab under 'Advanced HTTP and system settings' and save.
- or alternatively: shut down ums, then in UMS.conf set
http_engine_v2 = false
- restart and attach logs.
OK I have done this and attached is the debug log
- (23.04 KiB) Downloaded 547 times
Thx again, if possible could you now try this build (with and without http_engine_v2): UMS-1bbfc78.exe.
Thanks again
- without ums_dbg.zip
- (23.55 KiB) Downloaded 536 times
- with http_engine_v2_ums_dbg.zip
- (24.29 KiB) Downloaded 521 times
