Problem with audio sync (Panasonic TV)
Re: Problem with audio sync (Panasonic TV)
1. Your zip file includes your Panasonic-Viera.conf file without any modification to the line:
Maybe try to change this line in renderer conf:
Change it to "MPEGTS-H264-AAC" if anything change?
I thought when "MPEGTS-H264-AC3" is used, it is relevat only for re-encoding and not for remuxed videos so AAC audio is not needed to be transcoded to AC3 but maybe it is due to the fact you didn't removed the part I mentioned as your debug.zip file include renderer conf without changes.
Mentioning link to the FFmpeg FAQ was not to help you but that some tips from there can be incorporated directly to UMS code itself
2. I don't get the reason why your AAC 2channel audio is reencoded to AC3 6-channel and not streamed as is.Supported = f:aac m:audio/x-m4a n:2 a:(?!alac).+
wifi signal jammer (saw from site jammerall ) is good at jamming bluetooth as well ?
