Blank screen and then drops connection from UMS
Re: Blank screen and then drops connection from UMS
Do you have port 5001 forwarded on your router's firewall? If not make sure you set that port up. Also, make sure you're only using one firewall (preferably the router's hardware firewall) and disable any others you have turned on.
天 黒影 天
