Problem Uploading attachments with IE9?
Re: Problem Uploading attachments with IE9?
OK so image uploads work for me via IE9, I'll try a zip
- debug.zip
- (5.72 KiB) Downloaded 541 times
Trying it with 64-bit version
- debug.zip
- (5.72 KiB) Downloaded 528 times
OK so I can't reproduce the problem. It may be related to your malware or maybe an IE9 addon.
It usually wont matter what browser you're using if you have some kind of serious malware/virus. Time to get some good antivirus software, go into safe mode, run a full/deep scan and hopefully you can get rid of it. Also, he already said Firefox was working (most likely because he hadn't used it before the infection and didn't already have a bunch of malware ridden toolbars installed on it).SubJunk wrote:It may be related to your malware
squadjot wrote:Yep firefox works
天 黒影 天
- Optimus_prime
No problems, i'll exercise a little restraint. Point taken for next timesquadjot wrote:Yeah, i get offended easily xD j/k
Go easy on me as this the first time having a go as a moderator.
Only way to learn is from your mistakes.
You're doing a great job Optimus! I really appreciate it
woah..enver saw the updates on this post..
Ok, fair enough.. i thought it was a common IE problem.
- Optimus_prime
Not even relevant to this topic. Besides it shows that you don't know much about phpbb or even how hosting works.sheilmolson wrote:Well, I would say that you will have to purchase the hosting server in this case because if the hosting server is not legally purchased then you won't be able to upload the attachments on the server and the problem of loading the site will occur. So I would suggest that first of all you purchase hosting server and then upload you files.
It's a spammer, feel free to ban
- Optimus_prime
i thought as much, banned
