problems with audio and ffmpeg
mrtickle
Re: problems with audio and ffmpeg
Post by mrtickle »
DeFlanko wrote:
Can you do a fresh install -- I think there is a UMS Service installed once before but not now:
DEBUG 2013-12-08 11:57:32.631 [AWT-EventQueue-0] Starting "C:\Program Files\Universal Media Server\win32\service\wrapper.exe" -r wrapper.conf
DEBUG 2013-12-08 11:57:33.038 [Thread-20] wrapper  | The Universal Media Server service is not installed - The specified service does not exist as an installed service. (0x424)
ok. I did do a fresh install as there were many changes since my old Feb version. It by default wanted to install it as a service, but I didn't want that, and I run it not as a service. I don't know why it was trying to also run itself as a service after already starting up.
Also a Directory that is no longer available?
WARN  2013-12-08 12:14:47.540 [New I/O worker #12] The directory M:\ does not exist. Please remove it from your Shared folders list on the Navigation/Share Settings tab
That's my DVD-ROM drive. When I use UMS to watch a DVD on the PS3, or AVI files that are on my vast collection of burned DVDs, I put the disc into the drive. The rest of the time, the drive is empty and I get that error. I don't really like seeing it as an error, it's a big nagging, I have deliberately shared drive M for a reason! I certainly would never keep adding and removing drive M to the shares based on when I want to play a file from a DVD. An enhancement might be to not nag with that message if it's a physical drive that is not available, but I am happy to live with that minor point as it's just a line in a logfile which I know about and can safely ignore.
I think this might be your issue:
DEBUG 2013-12-08 12:23:42.254 [Thread-59] [VD_FFMPEG] DRI failure.
DEBUG 2013-12-08 12:23:47.832 [Thread-56] Cannot grow buffer size from 52,428,800 bytes to 209,715,200 bytes.
DEBUG 2013-12-08 12:23:47.832 [Thread-56] Error given: java.lang.OutOfMemoryError: Java heap space
DEBUG 2013-12-08 12:23:47.973 [Thread-56] Cannot grow buffer size from 52,428,800 bytes to 233,550,643 bytes either.
Hmm. I don't know why it's using so much memory. Nevertheless it shouldn't need FFMPEG to play a simple mp3 file on the ps3, as the ps3 should play mp3 natively?
mrtickle
Post by mrtickle »
SubJunk wrote:That debug info shows there were a lot of files played, can you tell us which one/s you had problems with?
Yes, sure I'll check through. May do another log with the newer version.
mrtickle
Post by mrtickle »
Here are my later tests and a new logfile which is hopefully clearer.
ums_dbg_mrt_20131211.zip
(77.29 KiB) Downloaded 527 times
test 1. 18:31:39.968
Kermode_10121019 Tim Burton.mp3
Failed with Network Error 80710736 on the PS3.
There is also a pregnant pause (6 seconds) before the screen changed on the PS3 and it failed showing the error.
test 2. 18:31:52.281
repeated same file.
failed the same way.
test 3. 18:32:05.390
Kermode_20120106 Ralph Fiennes.mp3
failed the same way
test 4. 18:32:22.375
Kermode_20120113 Steven Spielberg.mp3
This played fine! :mrgreen:
test 5. 18:32:40.968
Back to Kermode_20120106 Ralph Fiennes.mp3
failed as above.
test 6. 18:32:56.953
I repeated "Kermode_20120113 Steven Spielberg.mp3" again, the file from test 4.
this time it failed, but it's the same file that just worked a minute ago! :cry: Failure was as above.
HTH
ps this seems an odd message in the way it is written - Overriding detected mime type "audio/mpeg"... with "audio/mpeg" (ie the same thing)?
TRACE 2013-12-11 18:31:29.015 [New I/O worker #9] Overriding detected mime type "audio/mpeg" for file "Kermode_10121019 Tim Burton.mp3" with renderer preferred mime type "audio/mpeg"
mrtickle
Post by mrtickle »
bump. I have now updated to the latest version and I still have this problem. :cry:
Are there any other logfiles you need from me to find out what's causing this problem please?
mrtickle
Post by mrtickle »
I have now updated to version 3.4.2 and still have the problem :(
As before please let me know whatever I can do to help track it down.
