[Solved] No Sound Playing some mp4 files
Re: No Sound Playing some mp4 files
I've made a test build for you which will convert the sample rate to 48kHz when using FFmpeg, please see if it fixes your issue:
http://www.spirton.com/uploads/UMS/UMS- ... ersion.exe
Supermanfan77
Post by Supermanfan77 »
SubJunk wrote:I've made a test build for you which will convert the sample rate to 48kHz when using FFmpeg, please see if it fixes your issue:
SubJunk, is there a way to do the same thing with FFmpeg web video? Or would that be just the same setting?
Sure, if giskard confirms that this works I will probably add it to that too
giskard
Post by giskard »
It works great now. I have sound for mp4 and avi files that are either 22kHz or 24kHz. Thanks for all your help.
Re: [Solved] No Sound Playing some mp4 files
That's great news, thanks for testing! The fix will be in the next UMS release
Supermanfan77
Good I am glad that works. SubJunk, please do add that to FFmpeg for web videos, some sites using Jumpy have audio encoded in 16KHz mono.
That's done too, Supermanfan77 :) Feel free to build the latest master to use it, or if you want me to post a download link to a pre-release build I can make one later. Just let me know which operating system it's for.
Supermanfan77
SubJunk wrote:That's done too, Supermanfan77 :) Feel free to build the latest master to use it, or if you want me to post a download link to a pre-release build I can make one later. Just let me know which operating system it's for.
If you could post a download link to the pre-release, when you get a chance, that would be great, for windows 10 Java 8. My knowledge of building programs is nonexistent right now :lol:
Supermanfan77
Thanks SubJunk, that worked beautifully.
