Compatible transcoding for Xbox 360
barnito
Re: Compatible transcoding for Xbox 360
Post by barnito »
I always keep the latest FFMPEG installed from here... http://ffmpeg.zeranoe.com/builds/ x64 works on PMS 1.72
OK. Please post logs from PMS 1.72 and UMS 2.6.1 so that I can compare them
barnito
Post by barnito »
ok, PMS 1.72 buffer fills in less than 5 seconds, usually before the 360 gets past the "opening" message, playing fine: http://pastebin.com/KkShR294
UMS 2.6.1 with the buffer never getting above 1-2 MB stuttering: http://pastebin.com/XM5ai7LS
Hmm OK I think I see what it is now. Can you please try this version, and please try with both MEncoder and FFmpeg: http://www.spirton.com/uploads/UMS/UMS-barnito-2.exe
barnito
Post by barnito »
testing now
barnito
Post by barnito »
ok, now all the videos that need transcoding are gone, just shows other files and an empty transcode folder...
Videos that don't require transcode play fine
Cool, we're making progress. Please try this one http://www.spirton.com/uploads/UMS/UMS-barnito-3.exe and if it doesn't work please provide logs
barnito
Post by barnito »
unplayable content
INFO  2013-04-17 03:29:25.286 [main] Starting Universal Media Server 3.0.0
INFO  2013-04-17 03:29:25.352 [main] Based on PS3 Media Server by shagrath, copyright 2008-2013
INFO  2013-04-17 03:29:25.357 [main] http://www.universalmediaserver.com
INFO  2013-04-17 03:29:25.360 [main]
INFO  2013-04-17 03:29:25.360 [main] Build: a1fe721bc (2013-04-17)
INFO  2013-04-17 03:29:25.362 [main] Java: 1.7.0_17 - 64bit - Oracle Corporation
INFO  2013-04-17 03:29:25.365 [main] OS: Windows 7 64-bit 6.1
INFO  2013-04-17 03:29:25.366 [main] Encoding: UTF-8
INFO  2013-04-17 03:29:25.368 [main] Memory: 1137 MB
INFO  2013-04-17 03:29:25.369 [main] Working directory: C:\Program Files (x86)\Universal Media Server
INFO  2013-04-17 03:29:25.377 [main] Temp directory: C:\Users\JIMBAR~1\AppData\Local\Temp\universalmediaserver
INFO  2013-04-17 03:29:25.380 [main] Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO  2013-04-17 03:29:25.381 [main] debug.log: C:\Program Files (x86)\Universal Media Server\debug.log
INFO  2013-04-17 03:29:25.382 [main]
INFO  2013-04-17 03:29:25.383 [main] Profile directory: C:\ProgramData\UMS
INFO  2013-04-17 03:29:25.383 [main] Profile path: C:\ProgramData\UMS\UMS.conf
INFO  2013-04-17 03:29:25.384 [main] Profile permissions: rw
INFO  2013-04-17 03:29:25.385 [main] Profile name: SERVER
INFO  2013-04-17 03:29:25.386 [main]
INFO  2013-04-17 03:29:25.398 [main] Loading MediaInfo library
INFO  2013-04-17 03:29:25.513 [main] Loaded MediaInfoLib - v0.7.62
INFO  2013-04-17 03:29:25.519 [main] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
INFO  2013-04-17 03:29:25.520 [main] Loading configuration file: AirPlayer.conf
INFO  2013-04-17 03:29:25.529 [main] Loading configuration file: Android.conf
INFO  2013-04-17 03:29:25.533 [main] Loading configuration file: BlackBerryPlayBook-KalemSoftMP.conf
INFO  2013-04-17 03:29:25.540 [main] Loading configuration file: Bravia4500.conf
INFO  2013-04-17 03:29:25.544 [main] Loading configuration file: Bravia5500.conf
INFO  2013-04-17 03:29:25.548 [main] Loading configuration file: BraviaEX.conf
INFO  2013-04-17 03:29:25.572 [main] Loading configuration file: BraviaEX620.conf
INFO  2013-04-17 03:29:25.578 [main] Loading configuration file: BraviaHX.conf
INFO  2013-04-17 03:29:25.584 [main] Loading configuration file: DirecTVHR.conf
INFO  2013-04-17 03:29:25.586 [main] Loading configuration file: DLinkDSM510.conf
INFO  2013-04-17 03:29:25.589 [main] Loading configuration file: FreeboxHD.conf
INFO  2013-04-17 03:29:25.591 [main] Loading configuration file: FreecomMusicPal.conf
INFO  2013-04-17 03:29:25.593 [main] Loading configuration file: iPad-iPhone.conf
INFO  2013-04-17 03:29:25.596 [main] Loading configuration file: Kuro.conf
INFO  2013-04-17 03:29:25.599 [main] Loading configuration file: LGST600.conf
INFO  2013-04-17 03:29:25.603 [main] Loading configuration file: N900.conf
INFO  2013-04-17 03:29:25.606 [main] Loading configuration file: NetgearNeoTV.conf
INFO  2013-04-17 03:29:25.609 [main] Loading configuration file: OnkyoTX-NR717.conf
INFO  2013-04-17 03:29:25.610 [main] Loading configuration file: OPPOBDP83.conf
INFO  2013-04-17 03:29:25.612 [main] Loading configuration file: OPPOBDP93.conf
INFO  2013-04-17 03:29:25.614 [main] Loading configuration file: Panasonic.conf
INFO  2013-04-17 03:29:25.622 [main] Loading configuration file: Philips.conf
INFO  2013-04-17 03:29:25.624 [main] Loading configuration file: PhilipsPFL.conf
INFO  2013-04-17 03:29:25.630 [main] Loading configuration file: PopcornHour.conf
INFO  2013-04-17 03:29:25.632 [main] Loading configuration file: PS3.conf
INFO  2013-04-17 03:29:25.636 [main] Loading configuration file: Realtek.conf
INFO  2013-04-17 03:29:25.639 [main] Loading configuration file: Samsung-SMT-G7400.conf
INFO  2013-04-17 03:29:25.643 [main] Loading configuration file: SamsungAllShare.conf
INFO  2013-04-17 03:29:25.646 [main] Loading configuration file: SamsungWiseLink.conf
INFO  2013-04-17 03:29:25.648 [main] Loading configuration file: SharpAquos.conf
INFO  2013-04-17 03:29:25.651 [main] Loading configuration file: Showtime3.conf
INFO  2013-04-17 03:29:25.655 [main] Loading configuration file: Showtime4.conf
INFO  2013-04-17 03:29:25.658 [main] Loading configuration file: SMP-N100.conf
INFO  2013-04-17 03:29:25.662 [main] Loading configuration file: SonyBluray.conf
INFO  2013-04-17 03:29:25.665 [main] Loading configuration file: SonyHomeTheatreSystem.conf
INFO  2013-04-17 03:29:25.668 [main] Loading configuration file: Streamium.conf
INFO  2013-04-17 03:29:25.670 [main] Loading configuration file: TelstraTbox.conf
INFO  2013-04-17 03:29:25.671 [main] Loading configuration file: VideoWebTV.conf
INFO  2013-04-17 03:29:25.673 [main] Loading configuration file: VizioSmartTV.conf
INFO  2013-04-17 03:29:25.677 [main] Loading configuration file: WDTVLive.conf
INFO  2013-04-17 03:29:25.679 [main] Loading configuration file: WMP.conf
INFO  2013-04-17 03:29:25.681 [main] Loading configuration file: XBMC.conf
INFO  2013-04-17 03:29:25.683 [main] Loading configuration file: XBOX360.conf
INFO  2013-04-17 03:29:25.685 [main] Loading configuration file: YamahaRXA1010.conf
INFO  2013-04-17 03:29:25.687 [main] Loading configuration file: YamahaRXV3900.conf
INFO  2013-04-17 03:29:25.688 [main] Loading configuration file: YamahaRXV671.conf
INFO  2013-04-17 03:29:25.689 [main] Please wait while we check the MPlayer font cache, this can take a minute or so.
DEBUG 2013-04-17 03:29:25.690 [main] Launching: win32/mplayer.exe
DEBUG 2013-04-17 03:29:26.293 [main] Launching: win32/mplayer.exe
INFO  2013-04-17 03:29:26.440 [main] Finished checking the MPlayer font cache.
DEBUG 2013-04-17 03:29:26.449 [main] AviSynth plugins directory: C:\Program Files (x86)\AviSynth\plugins
INFO  2013-04-17 03:29:26.449 [main] VSFilter / DirectVobSub was not found. This can cause problems when trying to play subtitled videos with AviSynth.
INFO  2013-04-17 03:29:26.450 [main] Found VideoLAN version 2.0.1 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
ERROR 2013-04-17 03:29:26.451 [main] Only VLC versions 2.0.2 and above are supported
INFO  2013-04-17 03:29:26.457 [main] Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
INFO  2013-04-17 03:29:26.459 [main] No plugins found
INFO  2013-04-17 03:29:26.491 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO  2013-04-17 03:29:26.492 [main] Registering transcoding engine: FFmpeg Audio
INFO  2013-04-17 03:29:26.497 [main] Registering transcoding engine: MEncoder
INFO  2013-04-17 03:29:26.498 [main] Registering transcoding engine: AviSynth/MEncoder
INFO  2013-04-17 03:29:26.499 [main] Registering transcoding engine: FFmpeg
DEBUG 2013-04-17 03:29:26.500 [main] Found VLC version 2.0.1 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2013-04-17 03:29:26.500 [main] Registering transcoding engine: VLC
INFO  2013-04-17 03:29:26.501 [main] Registering transcoding engine: MPlayer Audio
DEBUG 2013-04-17 03:29:26.750 [main] FFmpeg supported protocols: [bluray, cache, concat, crypto, data, file, gopher, hls, http, httpproxy, https, mmsh, mmst, pipe, rtp, srtp, tcp, tls, udp, rtmp, rtmpe, rtmps, rtmpt, rtmpte, mms, https]
INFO  2013-04-17 03:29:26.757 [main] Registering transcoding engine: FFmpeg Web Video
INFO  2013-04-17 03:29:26.758 [main] Registering transcoding engine: MEncoder Web
INFO  2013-04-17 03:29:26.759 [main] Registering transcoding engine: MPlayer Video Dump
INFO  2013-04-17 03:29:26.759 [main] Registering transcoding engine: MPlayer Web
INFO  2013-04-17 03:29:26.761 [main] Registering transcoding engine: tsMuxeR
INFO  2013-04-17 03:29:26.762 [main] Registering transcoding engine: Audio High Fidelity
DEBUG 2013-04-17 03:29:26.763 [main] Found VLC version 2.0.1 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2013-04-17 03:29:26.763 [main] Registering transcoding engine: VLC Audio Streaming
DEBUG 2013-04-17 03:29:26.764 [main] Found VLC version 2.0.1 in Windows Registry: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
INFO  2013-04-17 03:29:26.764 [main] Registering transcoding engine: VLC Video Streaming
INFO  2013-04-17 03:29:26.765 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO  2013-04-17 03:29:26.766 [main] Registering transcoding engine: dcraw Thumbnailer
INFO  2013-04-17 03:29:26.859 [main] Using address /192.168.1.2 found on network interface: name:eth5 (NVIDIA nForce 10/100/1000 Mbps Ethernet )
INFO  2013-04-17 03:29:26.860 [main] Created socket: /192.168.1.2:5001
DEBUG 2013-04-17 03:29:26.989 [main] Sending ALIVE...
INFO  2013-04-17 03:29:27.030 [main] Using the following UUID configured in UMS.conf: fe80320f-6a71-400d-87e7-93b0fe848753
INFO  2013-04-17 03:29:27.157 [New I/O worker #1] No IP filter specified, access granted to /192.168.1.141
INFO  2013-04-17 03:29:27.187 [pool-7-thread-1] Checking IP: 192.168.1.141 for Xbox 360
DEBUG 2013-04-17 03:29:27.210 [New I/O worker #1] HTTP User-Agent: Xbox/2.0.16203.0 UPnP/1.0 Xbox/2.0.16203.0
DEBUG 2013-04-17 03:29:27.214 [New I/O worker #1] DLNA changes for Xbox 360
INFO  2013-04-17 03:29:27.286 [main] The server is now available for renderers to find
DEBUG 2013-04-17 03:29:31.261 [New I/O worker #2] DLNA changes for Xbox 360
INFO  2013-04-17 03:29:31.477 [New I/O worker #4] Checking shared folder: E:\Webshare\Video
INFO  2013-04-17 03:29:31.478 [New I/O worker #4] Checking shared folder: F:\Webshare\Shows and Clips
INFO  2013-04-17 03:29:32.305 [pool-7-thread-1] Renderer Xbox 360 found on this address: 192.168.1.141
DEBUG 2013-04-17 03:29:32.311 [pool-7-thread-1] Starting ping -n 3 -l 64000 192.168.1.141
DEBUG 2013-04-17 03:29:32.730 [Thread-14]
DEBUG 2013-04-17 03:29:32.730 [Thread-14] Pinging 192.168.1.141 with 64000 bytes of data:
INFO  2013-04-17 03:29:33.822 [UPNPHelper] No IP filter specified, access granted to /192.168.1.20
DEBUG 2013-04-17 03:29:34.311 [SpeedStats Failsafe] Stopping process: ping-0
DEBUG 2013-04-17 03:29:37.286 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2013-04-17 03:29:47.496 [New I/O worker #8] Starting transcode/remux of 30 Minutes or Less  2011 1080p BRRip .mkv
DEBUG 2013-04-17 03:29:47.508 [ffmpeg.exe-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -y -loglevel warning -i "E:\Webshare\Video\HD_Movies\30 Minutes or Less  2011 1080p BRRip x264 aac vice (HDScene Release)\30 Minutes or Less  2011 1080p BRRip .mkv" -map 0:2 "C:\ProgramData\UMS\data\subs\30 Minutes or Less  2011 1080p BRRip .mkv_EMB_ID0.ass"
DEBUG 2013-04-17 03:29:47.559 [ffmpeg.exe-1] Attaching thread: ffmpeg.exe-1
DEBUG 2013-04-17 03:29:57.344 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-04-17 03:30:09.973 [ffmpeg.exe-2] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -y -loglevel warning -threads 4 -i "E:\Webshare\Video\HD_Movies\30 Minutes or Less  2011 1080p BRRip x264 aac vice (HDScene Release)\30 Minutes or Less  2011 1080p BRRip .mkv" -threads 4 -vf "ass=C\\:/ProgramData/UMS/data/subs/30 Minutes or Less  2011 1080p BRRip .mkv_EMB_ID0.ass" -bufsize 1835000 -maxrate 14000000 -ac 6 -ab 384k -g 5 -q:v 1 -qmin 2 -c:a ac3 -c:v mpeg2video -f vob pipe:
DEBUG 2013-04-17 03:30:10.038 [ffmpeg.exe-2] Attaching thread: ffmpeg.exe-2
DEBUG 2013-04-17 03:30:11.414 [Thread-20] [Parsed_ass_0 @ 0226c6a0] Added subtitle file: 'C:/ProgramData/UMS/data/subs/30 Minutes or Less  2011 1080p BRRip .mkv_EMB_ID0.ass' (2 styles, 1410 events)
DEBUG 2013-04-17 03:30:11.913 [Thread-20] [Parsed_ass_0 @ 0226c6a0] Neither PlayResX nor PlayResY defined. Assuming 384x288
INFO  2013-04-17 03:30:16.009 [StartPlaying Event] Started playing 30 Minutes or Less  2011 1080p BRRip .mkv on your Xbox 360
DEBUG 2013-04-17 03:30:16.030 [StartPlaying Event] The full filename of which is: E:\Webshare\Video\HD_Movies\30 Minutes or Less  2011 1080p BRRip x264 aac vice (HDScene Release)\30 Minutes or Less  2011 1080p BRRip .mkv and the address of the renderer is: 192.168.1.141
barnito
Post by barnito »
Wait, worked the second time... but now FFMPEG is taking all unused cpu time, hang on
barnito
Post by barnito »
cache still doesn't fill, although it got to 20MB and gradually went down to 0, skipping still, although it is nice that subs are working, FFMPEG is using 100% CPU time.
INFO  2013-04-17 03:37:22.244 [New I/O worker #3] Starting transcode/remux of 30 Minutes or Less  2011 1080p BRRip .mkv
DEBUG 2013-04-17 03:37:22.258 [ffmpeg.exe-2] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -y -loglevel warning -threads 4 -i "E:\Webshare\Video\HD_Movies\30 Minutes or Less  2011 1080p BRRip x264 aac vice (HDScene Release)\30 Minutes or Less  2011 1080p BRRip .mkv" -threads 4 -vf "ass=C\\:/ProgramData/UMS/data/subs/30 Minutes or Less  2011 1080p BRRip .mkv_EMB_ID0.ass" -bufsize 1835000 -maxrate 14000000 -ac 6 -ab 384k -g 5 -q:v 1 -qmin 2 -c:a ac3 -c:v mpeg2video -f vob pipe:
DEBUG 2013-04-17 03:37:22.281 [ffmpeg.exe-2] Attaching thread: ffmpeg.exe-2
DEBUG 2013-04-17 03:37:22.394 [Thread-20] [Parsed_ass_0 @ 0239c400] Added subtitle file: 'C:/ProgramData/UMS/data/subs/30 Minutes or Less  2011 1080p BRRip .mkv_EMB_ID0.ass' (2 styles, 1410 events)
DEBUG 2013-04-17 03:37:22.425 [Thread-20] [Parsed_ass_0 @ 0239c400] Neither PlayResX nor PlayResY defined. Assuming 384x288
INFO  2013-04-17 03:37:28.267 [StartPlaying Event] Started playing 30 Minutes or Less  2011 1080p BRRip .mkv on your Xbox 360
DEBUG 2013-04-17 03:37:28.268 [StartPlaying Event] The full filename of which is: E:\Webshare\Video\HD_Movies\30 Minutes or Less  2011 1080p BRRip x264 aac vice (HDScene Release)\30 Minutes or Less  2011 1080p BRRip .mkv and the address of the renderer is: 192.168.1.141
DEBUG 2013-04-17 03:37:31.338 [New I/O worker #6] Setting InputStream new position to: 5,640
INFO  2013-04-17 03:38:04.072 [New I/O worker #1] No IP filter specified, access granted to /192.168.1.146
INFO  2013-04-17 03:38:04.075 [New I/O worker #1] Another renderer like Xbox 360 was found!
DEBUG 2013-04-17 03:38:04.077 [New I/O worker #1] HTTP User-Agent: Xbox/2.0.16203.0 UPnP/1.0 Xbox/2.0.16203.0
INFO  2013-04-17 03:38:04.077 [pool-7-thread-2] Checking IP: 192.168.1.146 for Xbox 360
INFO  2013-04-17 03:38:08.686 [pool-7-thread-2] Renderer Xbox 360 found on this address: 192.168.1.146
DEBUG 2013-04-17 03:38:08.688 [pool-7-thread-2] Starting ping -n 3 -l 64000 192.168.1.146
DEBUG 2013-04-17 03:38:08.795 [Thread-25]
DEBUG 2013-04-17 03:38:08.796 [Thread-25] Pinging 192.168.1.146 with 64000 bytes of data:
DEBUG 2013-04-17 03:38:10.699 [SpeedStats Failsafe] Stopping process: ping-3
DEBUG 2013-04-17 03:38:24.086 [New I/O worker #8] Setting margin to 2Mb
DEBUG 2013-04-17 03:40:17.741 [UPNP-AliveMessageSender] Sending ALIVE...
INFO  2013-04-17 03:41:18.501 [UPNPHelper] No IP filter specified, access granted to /192.168.1.3
DEBUG 2013-04-17 03:41:41.843 [Buffered IO End Checker] Stopping process: ffmpeg.exe-2
INFO  2013-04-17 03:41:43.344 [StopPlaying Event] Stopped playing 30 Minutes or Less  2011 1080p BRRip .mkv on your Xbox 360
DEBUG 2013-04-17 03:41:43.346 [StopPlaying Event] The full filename of which is: E:\Webshare\Video\HD_Movies\30 Minutes or Less  2011 1080p BRRip x264 aac vice (HDScene Release)\30 Minutes or Less  2011 1080p BRRip .mkv and the address of the renderer is: 192.168.1.141
