Playback Impossible: Transcoded MKV!
Re: Playback Impossible: Transcoded MKV!
dadish
Post by dadish »
Did not work same issue is still there. It transcodes and begins to play then for some reason the bar gets dumped/cleared or something and it buffers again, this loops. Have attached the logs.
3.0.0-Not-working-ums_dbg-TRACE.zip
(184.84 KiB) Downloaded 607 times
OK time to track down what exactly caused this to happen :)
Can you let me know the results from these 2 versions?
http://www.spirton.com/uploads/UMS/UMS-6ba30bb.exe
http://www.spirton.com/uploads/UMS/UMS-8a25a01.exe
(the links will work about 20 mins after I posted this)
dadish
Post by dadish »
Not working, though i'm getting a File Format error on my TV now. Logs attached. Did everything the same from other builds started a play without transcode it worked fine without any issues then chose mencoder from the TRANSCODER folder and it did not work but now it gave me that the file format is not supported (something like that, translated from swedish).
Build 8a25a01aa-NotWorkingtotranscode-ums_dbg.zip
(27.88 KiB) Downloaded 601 times
Build 6ba30bbca-NotWorkingtotranscode-ums_dbg.zip
(33.18 KiB) Downloaded 722 times
dadish
Post by dadish »
Still not working. Same issue "file format is not supported" error. Logs attached
Build 8516f2208-Not-Working-Transcode-ums_dbg.zip
(27.69 KiB) Downloaded 885 times
Build 78a646cfa-Not-Working-Transcode-ums_dbg.zip
(26.61 KiB) Downloaded 808 times
Can you please post a debug log from the first version with the bug - 2.5.1? I have a log for that version but not with trace enabled
dadish
Post by dadish »
Here you go. Are you getting closer to narrowing down what the issue is?
2.5.1-Not-Working-Transcode_ums_dbg.zip
(41.9 KiB) Downloaded 798 times
vienmnguyen
Post by vienmnguyen »
Wow, this is really top notch support. Bravo! (Even though the issue isn't even solved yet)
Does replacing renderers/SamsungAllShare.conf with the attached one fix it?
vienmnguyen wrote:Wow, this is really top notch support. Bravo! (Even though the issue isn't even solved yet)
Thanks :D
(1.85 KiB) Downloaded 656 times
