Toshiba TV not able to detect UMS after firmware upgrade
Sami32
Re: Toshiba TV not able to detect UMS after firmware upgrade
Post by Sami32 »
Joker, you did repost a new ZIP, we can saw it as it's write not downloaded yet ;) That's fine.
Could you try this testing renderer and post a new log if you're still having issue: (add it in your renderer UMS subfolder)
Toshiba-L7453D.conf
(1.77 KiB) Downloaded 679 times
And set this line in the "Use an IP filter (whitelist)" and restart UMS:
192.168.1.3,192.168.1.4
You seem have a network issue, something block. If you still get issue, could try to disable briefly your firewall(s) to test if that make any difference ?
Your TV identify itself correctly, but UMS never sended a default renderer.
Now you should be able to see your Toshiba renderer displayed in UMS, right ?
EDIT: Sorry, i modified the IP values above.
