4k File not streaming
Re: 4k File not streaming
Hey,
I have updated the UMS and added the new log.
Attached is the log file.
Now I cant even see the file when I go into the folder and then I will look into a different folder and other files show.
When I go back to that folder to see if it now shows, it show the folder I just went to files.
Hope that makes sense.
Thanks,
Thanks,
Also noticed that the tv Ethernet is 10/100 on the TV. does that make a difference?
Hey
I got the stream to work.
I did a reinstall of UMS and was able to play the file.
I however have run into another issue. that file plays fine but my others lag.
it looks like it could be a issue of connection speed but I'm just not sure.
The difference in file size from the one that's working is 38GB and 48GB is the new one that's lags.
I have all my movies on a external drive connected by USB 3.0 and my network in a gigabit network.
I looked at my Ethernet connection in task manager while running the bigger file and it only goes at about 50Mbps so should have plenty of more room to accommodate the transfer. I think my new TV is only 10/100 but that should still be enough connection speed for it I would have thought.
Any thoughts on this would be helpful, I have attached the debug. Thanks for the time you have put into this
Your test wasn't done with the new renderer that i posted for you.
Could post a new log using the renderer AND the UMS beta that i posted, after having played one video that work fine and some others that didn't ?
Thank you for your understanding.
