PS4 now support DLNA!
Audioboxer
Re: PS4 now support DLNA!
Post by Audioboxer »
Does anyone else's copy on Windows 10 crash due to Java hogging a ton of memory and then freezing?
hiroshawn
Post by hiroshawn »
I cant get this to work for the life me. I downloaded the media player on PS4 and I downloaded UMS. The PS4 isn't detecting it though. What a I doing wrong?
Lasher
Post by Lasher »
hiroshawn wrote:I cant get this to work for the life me. I downloaded the media player on PS4 and I downloaded UMS. The PS4 isn't detecting it though. What a I doing wrong?
it all depends how you have everything set up ... if you have an antivirus/firewall it could be blocking them seeing each other ... also are you running this wireless or via ethernet
more info would help us to help you :)
@audioboxer ... sorry im still on windows 7 ... so dont know about windows 10 ... stupid question but have you updated to the latest java as they rolled out a update a week or so ago ... other then that i have no idea
Audioboxer
Turning off cache seems to have fixed my issues!
AlGrenadine
Post by AlGrenadine »
Am i the only one having A/V sync issues with UMS latest version on AVI files ?
gumbyx84
Post by gumbyx84 »
I've been running into issue streaming to my PS4 using UMS 5.2.1 though not in the same way you guys are. When playing a video, it will randomly start to stutter or freeze up all together. The videos are just MP4 with AC3 audio encoding so there shouldn't be any transcoding. I am running both over a 2.5GHz wireless network, but I do not have this problem with my PS3 that is on the same network with the same video files.
CascaCure
Post by CascaCure »
Hey guys,
Any way to change Aspect Ratio? All the videos I've played on PS4 with UMS seem to be in 4:3 with black bars on the left and right. I'm running ps4 on a 32 HDTV at 1080p. / UMS 5.2.1 / Win 7
Any help is greatly appreciated
Does anyone else have this issue?
michaelt
Post by michaelt »
SubJunk wrote:Does anyone else have this issue?
Yes - but not this configuration (see signature).
All my non-Blu-ray *.mkv videos get the pillar bars.
Extraction done with MakemKV.
. . . . and a few others.
Samsung UN55C8000
mero27
Post by mero27 »
Hi Guys,
so i have an issue with some video files, mainly anime, that i cannot fast forward or rewind in, and there's no timeline or minutes counter, any idea how i can fix this?
Thanks.
