[SOLVED] Problem for playing some videos
Re: Problem for playing some videos
Thanks, i can wait dont worry. It's Sunday, take your time
So, i finally build it: (your new renderer is already include inside it)
https://we.tl/Rd9xR1BB1s (link valid for 7 days)
As already said, it need a clean install to work correctly.
Try with [No transcoding] and [FFmpeg] as already explained.
I hope that this time you will be able to play your media.
Don't forget to joint a new trace log if it doesn't work, thanks.
Files still cannot be reads.
If i try to open any file in transcode folder it's says "unable to execute the request, return to the main screen"
Affected files display now "0.00kb"
Logs joined
Logs joined
- (1.06 MiB) Downloaded 1075 times
Hum... I have never tried version 7 but I have reinstalled your version and it does not work anyway
And some screenshots for version (it's the same number version since the last reinstall)
http://nsa39.casimages.com/img/2017/10/ ... 121058.png
http://nsa39.casimages.com/img/2017/10/ ... 236505.png
EDIT: logs joined
EDIT: logs joined
- (1.06 MiB) Downloaded 1040 times
Please, try that build instead:
https://we.tl/6y1ZsTUMj0
Disable "Resume" and "Recently played" in your GUI, just in case.
If it still doesn't work, add this line of code into your new renderer:
or that one instead
? i really don't know how your renderer will react to a such incorrect signed value.
Sorry for the deleted post, i mistaken your log with an other user log in my editor
Thank you for your understanding.
TranscodedVideoFileSize = 1000000000
TranscodedVideoFileSize = -1
No problem,
I tested your 3 ways but no change...
EDIT: log 1 = Your default build
Log 2 = with TranscodedVideoFileSize = 1000000000
Log 3 = TranscodedVideoFileSize = -1
- ums_dbg3.zip
- (306.22 KiB) Downloaded 1015 times
- ums_dbg2.zip
- (616.46 KiB) Downloaded 1126 times
- ums_dbg1.zip
- (565.66 KiB) Downloaded 971 times
Now i'm perplex...
- Can you play some videos at least ? or not even one ?
- Can you transcode some videos ?
- Do your videos play from your USB without using UMS ?
Same error message and a size of zero each time ?
EDIT:
Do using that renderer make any difference ?
EDIT:
Yes i can play lot of files. Maybe because the concerned file is in 50fps ? But some other files have the same problem and they are not in 50 fps- Can you play some videos at least ? or not even one ?
I cant open any transcode folder- Can you transcode some videos ?
After test, I cant play the concerned video on USB too. But with PS3/UMS it's work like a charm. It's why i have open this thread.- Do your videos play from your USB without using UMS ?
The new renderer make no changes
- (949.93 KiB) Downloaded 916 times
Could you post the advanced MediaInfo logs of 2 similar media, one that work and one that doesn't ?
Go in the "Debug" tab of MediaInfo and select "Advanced mode", then copy/paste or attach the files here.
Can you play some other 50 fps media ? H.265 codec from your USB ?
My renderer play them all, so i cannot reproduce what seem to be specific to Samsung.
