Version 1.3.0 is released
Madoka
Re: Version 1.3.0 is released
Post by Madoka »
1.3.0 also stopped playing 10-bit softsibbed anime. I get no picture, only sound.
Also, .mkv soft subs don't show up unless I put eng back into the "subtitle language priority" setting.
Back to 1.2.0 and everything plays fine.
phrozenstare
Post by phrozenstare »
I just found a new bug in 1.3.0. i found the "definitely disable subtitles" option no longer works
Madoka wrote:1.3.0 also stopped playing 10-bit softsibbed anime. I get no picture, only sound.
"eng" is in there by default in 1.3.0. By default the subtitle language priority is "loc,eng,fre,jpn,ger,und".
phrozenstare wrote:I just found a new bug in 1.3.0. i found the "definitely disable subtitles" option no longer works
Is that with ASS/SSA subtitles? If so, I've fixed it for the next release.
Madoka
Post by Madoka »
[quote="SubJunk]"eng" is in there by default in 1.3.0. By default the subtitle language priority is "loc,eng,fre,jpn,ger,und".[/quote]
Is it supposed to be in the settings? Because it's blank. I have to put "eng" in to get embedded softsubs to show up.
To make the default value show up you can clear the contents of the subtitle language priority box, save then restart the program.
phrozenstare
ok thanks subjunk
phrozenstare
i was going to edit my last post but couldn't find it.
anyway i went under subtitle settings and tried clearing ther forced sub box and saved settings and then restarted. once i restarted i found the forced sub box contained a value again. was this the setting you were talking about or was it something different?
thanks
phrozenstare
update: after findiong out clearing the boxese had no effect i was able to turn them off by putting the word off in the "forced tags" field i also placed it in the languages priority box
