new ums 3.0 final doesn't detect my ps3
Re: new ums 3.0 final doesn't detect my ps3
the second one (version 2.7) with filename b699ab2.exe works fine! the other one don't
Yay we found one that works
Now hopefully this one doesn't?
![Smile :)](./images/smilies/icon_e_smile.gif)
Yes this one also works.
No problem, thanks for helping.
they both work, keep on searching![Wink ;)](./images/smilies/icon_e_wink.gif)
The first one with filename 5d35779.exe works
the second one with filename f66deb3.exe doesn't work
Are you using 64-bit Java or 32-bit? If you're using 64-bit can you please try uninstalling it to see if that fixes it?
Oh my god everything works fine with version 3.1.0 now with 32 bit java.
How funny, is this some kind of bug?
thanks a lot, easy solution isn't it?
