[Solved] UMS Won't Startup
Re: UMS Won't Startup
Ok thanks. I'm away from my Windows computer until Thursday so I'll try to figure out how to build UMS for Windows on my mac and try to get some test builds to you ASAP
While I'm away from my Windows computer I'll post .jar files to test, so instead of running the installer I think you can just rename it to ums.jar and put it in the installation directory
https://www.universalmediaserver.com/up ... 42f4ca.jar
Provided ums.jar placed into the 9.0.0-b2 shows similar result of Java appearing in the task manager for 1-2 seconds before disappearing/ no debug.log or startup.
Ok thanks, how about https://www.universalmediaserver.com/up ... 0dd5a7.jar ? It's not an actual fix but might give me more of an idea about the cause
Also I see you've posted in this thread Nadahar, do you have any idea about it? Maybe I made a mistake when I merged that code in, or I missed some prior dependency
I'm not sure what the problem is, but I seem to vaguely remember something somewhat familiar that I might have fixed in DMS a long time ago. That said, it could be the merging as well.
I'd say that the easiest way would be to start UMS from the command line using "java.exe" instead of "javaw.exe":
"javaw.exe" hides all the console output, but "java.exe" does not. That means that the log will be output directly to the console so that you can catch an error that happens before the logging system is up and running.
java -jar ums.jar trace
Same result with the new provided .jar
Nadahur here is the error of the console that appears when the provided code is used.
C:\Program Files (x86)\Universal Media Server>java -jar ums.jar trace
Exception in thread "main" java.lang.ExceptionInInitializerError
at net.pms.configuration.PmsConfiguration.<init>(PmsConfiguration.java:613)
at net.pms.configuration.PmsConfiguration.<init>(PmsConfiguration.java:573)
at net.pms.PMS.main(PMS.java:1011)
Caused by: java.nio.file.InvalidPathException: Illegal char <"> at index 0: "C:\Program Files (x86)\Common Files\Oracle\Java\javapath
at sun.nio.fs.WindowsPathParser.normalize(Unknown Source)
at sun.nio.fs.WindowsPathParser.parse(Unknown Source)
at sun.nio.fs.WindowsPath.parse(Unknown Source)
at sun.nio.fs.WindowsFileSystem.getPath(Unknown Source)
at java.nio.file.Paths.get(Unknown Source)
at net.pms.util.FileUtil.getOSPath(FileUtil.java:2257)
at net.pms.util.FileUtil.findInOSPath(FileUtil.java:2312)
at net.pms.util.FileUtil.findExecutableInOSPath(FileUtil.java:2276)
at net.pms.configuration.WindowsProgramPaths.<init>(WindowsProgramPaths.java:113)
at net.pms.configuration.PlatformProgramPaths.<clinit>(PlatformProgramPaths.java:147)
... 3 more
This makes all the difference
The problem is caused by an invalid PATH environment variable. You shouldn't use double quotes inside the PATH, so just modify it and UMS (and other software that relies on the PATH) will start working.
https://www.architectryan.com/2018/03/1 ... indows-10/
https://www.java.com/en/download/help/path.xml
Works now!
Didn't see a path set with quotes there were 3 with reference to java and one of the path had a java+python mix. I deleted the three paths then reinstalled java now the there is one path and UMS works!!
Very nice, thanks both of you for the help and testing. Considering that it used to work, and that we seem to have a lot of people encountering the same problem, I am still interested in finding a way to support the invalid path.
If I make a proposed fix, can you please break your path again and test it, randomusername?
