[Solved] Sony X90J and X95J can't connect
Re: Sony X90J and X95J can't connect
This isn't that likely to work but it would be good to rule it out before trying more things:
https://www.universalmediaserver.com/up ... a-test.exe
Yawn, just woke up. It's 5:30am and just installed it. TV's are set to DHCP and only a few are STATIC.SubJunk wrote: ↑Sun Dec 26, 2021 7:45 pm This isn't that likely to work but it would be good to rule it out before trying more things:
Opened UMS and the files played no problem. 1080P and 4K UHD 10bit.
Changed to TRACE and the same issue happened again, No videos could play and the 1080P version of Wonder Woman was NOT even listed. Exited UMS and started again, then changed to TRACE and worked!
Here's the log file!
- ums_dbg_2021-12-26-05-28.zip
- (102.79 KiB) Downloaded 642 times
It might expect SystemUpdateID to be unique over time, so I'll make a build that does that soon
Ok please try https://www.universalmediaserver.com/up ... 370f77.exe
That should make it so the SystemUpdateID persists even when closing UMS, and also updates more often
Installed. Played all 3 videos like it should.SubJunk wrote: ↑Mon Dec 27, 2021 1:21 pm Ok please try https://www.universalmediaserver.com/up ... 370f77.exe
Will test on the TCL Roku's now. Did you update this to support without forcing the renderer?
Verified TCL Roku will only play if I goto "MEDIA LIBRARY", and not the actual DIR. So it's not updated for the TCL's. That should be a lot easier I assume.
Noticed this, (It's been doing this since the beginning)
-AV-Physical-Unit-Info: pa="BRAVIA ";
X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA "; mv="3.0";
20:28:42 INFO Media renderer was not recognized. Possible identifying HTTP headers:
User-Agent: UPnP/1.0
X-AV-Physical-Unit-Info: pa="BRAVIA ";
Attached is the log file!
- ums_dbg_2021-12-26-20-32.zip
- (96.36 KiB) Downloaded 484 times
That is great news! I guess the TCL renderers have a separate problem. It would be good to fix that too. I'll look at your logs.
Does that mean the new Sony's will be supported on the next public release?
Only the massive long post I made on page 2 has the TCL info. Forcing to ROKU ULTRA was a 100% success...
Yeah I think we can get this merged into the next release
here is the branch with the changes for you https://github.com/UniversalMediaServer ... /pull/2740
I think we can include the TCL renderer configs in the same branch, but before we do that I'd like to try to fix the bug you described where videos play in the Media Library but not outside of it.
Can you provide logs where you reproduce that?
The logs on page 2 have those logs but sure, I can do that!
I'm headed to bed. Spent the last 3 days painting the interior of my house. I'll get fresh TCL ROKU logs in am.
I'll log the TCL first with MEDIA GALLERY and then I'll force render ROKU ULTRA and provide those logs.
Thanks again for all your support. So far since years ago we got Sony, TV's, Vizio TV's and Sony Blu-rays to work with UMS and now the new Sony's! My one client will ne excited to hear his new X95J will stream from UMS now. You rock!
How to I pull from that merge? It's been a while since I used GitHub.... I forget how to compile to EXE on Windows.
