Version 3.4.0 is released
SergioBigRed
Re: Version 3.4.0 is released
Post by SergioBigRed »
awschmidt wrote:thanks for the new release, but UMS 3.4.0 can't work with movieinfo anymore.
Error:
02-06 20:07:47 Exception in thread "main" java.lang.NoSuchFieldError: EMPTY_BORDER
02-06 20:07:47 at net.pms.movieinfo.MovieInfo.config(MovieInfo.java:99)
02-06 20:07:47 at net.pms.newgui.PluginTab.appendPlugin(PluginTab.java:420)
02-06 20:07:47 at net.pms.newgui.PluginTab.addPlugins(PluginTab.java:413)
02-06 20:07:47 at net.pms.newgui.LooksFrame.serverReady(LooksFrame.java:568)
02-06 20:07:47 at net.pms.PMS.init(PMS.java:695)
02-06 20:07:47 at net.pms.PMS.createInstance(PMS.java:1018)
02-06 20:07:47 at net.pms.PMS.main(PMS.java:1114)
Same issue for me here, no showing on PS3.
Update from 3.3.0 maintaing the same config file (that I suspect I have since several upgrades...). I had to rollback to UMS 3.3.0 and all work fine.
Gareee
Post by Gareee »
I rolled back to 3.3.0 as well. My stereo does have dts, but apparently I don't have it set up properly to decode it while streaming through the ps3, so I was getting static when I selected a dts file for playback.
3.3.0 did not have the new config setup option, so I did a clean install of 4.4.0 to change that dts setting back, added my nav folders, and then installed 3.3.0 over the top of that to get everything working properly again.
MovieInfo support is fixed in 3.4.1 which will be released soon (today or tomorrow hopefully)
spkbr
Post by spkbr »
Error:
The same thing happens for LastFMScrobbler plugin. Removing it and the problem is gone. Do you think 3.4.1 will fix it for that too?
02-13 09:23:21 Exception in thread "main" java.lang.NoSuchFieldError: EMPTY_BORDER
02-13 09:23:21 at net.pms.external.LastFMScrobbler.config(LastFMScrobbler.java:140)
02-13 09:23:21 at net.pms.newgui.PluginTab.appendPlugin(PluginTab.java:420)
02-13 09:23:21 at net.pms.newgui.PluginTab.addPlugins(PluginTab.java:413)
02-13 09:23:21 at net.pms.newgui.LooksFrame.serverReady(LooksFrame.java:568)
02-13 09:23:21 at net.pms.PMS.init(PMS.java:695)
02-13 09:23:21 at net.pms.PMS.createInstance(PMS.java:1018)
02-13 09:23:21 at net.pms.PMS.main(PMS.java:1114)
The font cache thing is just perfect now! Thanks a lot SubJunk for listening to our complaints. Great work!
spkbr wrote:The same thing happens for LastFMScrobbler plugin. Removing it and the problem is gone. Do you think 3.4.1 will fix it for that too?
I just checked and yes it fixes that too :)
spkbr wrote:The font cache thing is just perfect now! Thanks a lot SubJunk for listening to our complaints. Great work!
Thanks :) The improvement was a team effort, thanks to skeptical and valib too :)
Gareee
Post by Gareee »
I just got an email notification of a update to UMS.. but it looks like its still 3.4.0, not 3.4.1.
Odd.
spkbr
Post by spkbr »
Then thank you SubJunk, skeptical and valib! :D :D
Monica Jae
Post by Monica Jae »
rollin back to 330
Monica Jae
ok, where is it?
Monica Jae
so i see that 3.4.1 is released, yet that isn't reflected on the dl page. i'm at github now and cannot get a working install??.. i know it's source, so... a little help
