Streaming suddenly stopped working
Re: Streaming suddenly stopped working
Nothing changed. Maybe this will improve on the next urlresolver version.infidel wrote:EDIT: Before you delete everything for good, can you test to see if urlresolver 2.2.0 fares any better if you (temporarily):
remove/rename the t0mm0 symlink.
install script.module.t0mm0.common.
lol...It's definitely not by choice. I don't want to live in the pastinfidel wrote:You seem to be living in the past mostly
I'm assuming this means "it didn't solve the issue" (and not "everything still works"R9deLima wrote:Nothing changed.
I've reproduced this but not consistently. Still not sure what the critical issue is, alas.R9deLima wrote:The buffer issue started on UMS 3.0.0 alpha 2 and no one identified the changes from alpha 1 one which works so I'm stuck with that.
No. It didn't solve the issue. Everything runs fine with the previous version so I'm good with that. But I will keep trying the latest versions and updates of everything so that I don't fall too far behindinfidel wrote:I'm assuming this means "it didn't solve the issue" (and not "everything still works").
