Sleep problems on OS X
Re: Sleep problems on OS X
did anybody found anything about that ? I can't figure out why nobody found something in ps3 media server that could solve our problem,
because it was working properly in that case.
please guys it's getting really annoying !
- Optimus_prime
What java version are you guys using as i will post a test version and see if that fixes your issue
- Optimus_prime
Ok i've made two versions for people to test. I've just reverted back to the ps3 media server code, so you can test it and see if it works
Java 6 Version: http://sourceforge.net/projects/unimedi ... -Java6.dmg
Java 8 Version: http://sourceforge.net/projects/unimedi ... -Java8.dmg
Mavericks (OS X 10.9) introduced a new feature called 'App Nap' which places applications that are hidden and not currently doing anything, into a paused state to save energy.
Try disabling App Nap:
Click on 'Universal Media Server.app' in Applications folder (or wherever your copy is installed) --> Click 'File' menu --> Click ''Get Info' --> check 'Prevent App Nap' checkbox in 'Universal Media Server.app Info' window.
Hopefully that fixes your problem.
I'm gonna try the app nap trick and if it doesn't work i'll try the other options, thanks guys !
Kefran,
This seems to work for me
Finally something that solves this issue.
Here's a happy chappy right now.
A thousand thanks to you.
Greetsssssssss Snakebyte
- Optimus_prime
I wonder if it's possible to put an option into UMS to do this just like the prevent windows option
I think it would be better to disable it and post a Notification - UMS can't run with it enabled.Optimus_prime wrote:I wonder if it's possible to put an option into UMS to do this just like the prevent windows option
Even cleaner - disable on launch, restore state on exit. No user action required.
. . . . and a few others.
Samsung UN55C8000
Samsung UN55C8000
Snakebyte,
I'm glad it solved the problem.
Michaelt,
I agree, I think it should be disabled at launch, if that is possible. I see no reason for allowing UMS to App Nap at all.
Michaelt,
- Optimus_prime
I'll investigate and see if it's possible to disable on start then reenable on shutdown. If i figure it out i'll post a version for testing, any help would be great
