[Solved] Samsung UE48H6670 subtitle problem
Re: Samsung UE48H6670 subtitle problem
External .srt files and the H series of the Samsung TV's do not play the subtitles. My previous tv also a D series had no problem with it, but since the upgrade to a bigger tv the problem started.bcs wrote:Hi!
Are you trying to use the embedded sub track or a separate sub file (.str)? My D series Samsung supports only external subs (must be the same filename as the video file). Maybe your H series have the same issue when streaming through UMS. You should put the subs into an external file and give it a shot (after removing the ffmpeg.exe).
bcs
And removing ffmpeg.exe did unfortunatly not work
Alright. Sorry mate I'm out of ideas.Franneke wrote:External .srt files and the H series of the Samsung TV's do not play the subtitles. My previous tv also a D series had no problem with it, but since the upgrade to a bigger tv the problem started.bcs wrote:Hi!
bcs
bcs
Update:
Just installed Universal Media Server Version 4.0.0-b1 as a test, and the subtitles work with ffmpeg on my Tv.
Thanks that is at least working now! Now I can watch the series with subtitles!!!
Great work guys!
Great work guys!
And a new update: Now the subtitles work without the transcode.
This is great!!!
Thanks a lot guys!
This is great!!!
Thanks a lot guys!
Huh?Franneke wrote:And a new update: Now the subtitles work without the transcode.
This is great!!!
Thanks a lot guys!
Still not working on my UE48H6600.
Regards,
Jens
Jens
I have latest UMS 4.1.1. and the software on my tv is fully updated as well, maybe that does it, do not know, I decided to test is during the weekend and the subtitles appeared out of the blue.pipin wrote:Huh?Franneke wrote:And a new update: Now the subtitles work without the transcode.
This is great!!!
Thanks a lot guys!
I was really happy!
Same here now with 4.2! Subtitles finally working.Franneke wrote:I have latest UMS 4.1.1. and the software on my tv is fully updated as well, maybe that does it, do not know, I decided to test is during the weekend and the subtitles appeared out of the blue.pipin wrote:Huh?Franneke wrote:And a new update: Now the subtitles work without the transcode.
This is great!!!
Thanks a lot guys!
I was really happy!
Regards,
Jens
Jens
- Optimus_prime
Re: [Solved] Samsung UE48H6670 subtitle problem
Guy's if Any release breaks Subtitles please post in the forums so we can have a look at it. Samsung Tv's are a cause for a lot of issues as there seems to be differences between models sometimes. Thanks for sticking with UMS
