Audio Not Supported
valib
Re: Audio Not Supported
Post by valib »
Now I would like to know which files are not shown at the TV. If you can please send the MediaInfo result for some of that files.
Scott817
Post by Scott817 »
Here is a screenhot. Sicario is one of them that doesnt show up. I can now verify that none of the mkv files are showing up after comparing type and what I see when going from movie to movie. I added shawshank redemtions by itself as it doesnt show up as well.
On the left side in MediaInfo, click to select "text" view. Then click somewhere on the text, press Ctrl + A to select all and then Ctrl + V to copy it. Paste the text here.
Scott817
Post by Scott817 »
Here you go.
General
Unique ID : 192386475093378910435982029644037389877 (0x90BC498E4FA2F822BAB0371DA96C7E35)
Complete name : E:\Movies\Movies\S\Shawshank Redemption\Shawshank Redemption.mkv
Format : Matroska
Format version : Version 1
File size : 2.76 GiB
Duration : 2 h 22 min
Overall bit rate : 2 771 kb/s
Encoded date : UTC 2009-03-06 11:07:22
Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : [email protected]
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 2 000 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.091
Stream size : 1.94 GiB (70%)
Writing library : x264 core 66 r1113M cc4f807
Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=4 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=2000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Default : Yes
Forced : No
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 392 MiB (14%)
Title : ??
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Bit rate : 384 kb/s
Channel(s) : 6 channels
Bit depth : 16 bits
Title : ??
Language : Chinese
Default : No
Forced : No
Text #1
Format : SSA
Codec ID : S_TEXT/SSA
Codec ID/Info : Sub Station Alpha
Compression mode : Lossless
Title : ??????1
Default : Yes
Forced : No
Text #2
Format : SSA
Title : ??????2
Default : No
Forced : No
Text #3
Format : SSA
Title : ????
Default : No
Forced : No
Text #4
Format : SSA
Title : ????
Default : No
Forced : No
valib
Post by valib »
I checked the manual of the TV and there is written:
• The server is required to be DLNA
Certified™.
• Files from a network device need to be in the
following formats:
– Still images: JPEG
– Music: MP3, linear PCM, WMA
– Video: AVCHD, MPEG2, MPEG1, MP4
(AVC), MP4 (MPEG4), WMV
• Depending on the file, playback may not be
possible even when using the supported
formats.
so I prepared the conf from supported formats playable from USB which means that not all video and audio formats could be played via DLNA. Than this is now only about testing. When is TV not showing some files may mean that there is a combination of not supported video or audio formats. As you can see from the log the GetProtocolInfo says that only those formats
 http-get:*:video/mpeg:*
  http-get:*:video/vnd.dlna.mpeg-tts:*
  http-get:*:video/avi:*
  http-get:*:video/x-ms-asf:*
  http-get:*:video/x-ms-wmv:*
  http-get:*:video/mp4:*
are supported. There is not an MKV and it may be disabled in the conf. I prepared new conf for testing.
Sony-BraviaR.conf
(4.52 KiB) Downloaded 538 times
Scott817
Post by Scott817 »
I just arrived home and have tested the new conf file and can report it is working great now with the current version. I can see and play all formats now! Thank you for your hard work. :D
