Testing UMS Built with JRE 7
Re: Testing UMS Built with JRE 7
Nice job :) By the way I'm releasing UMSBuilder 1.3 soon which will be more reliable at building
kuroukage
Post by kuroukage »
Thanks for the new build.
Just tested it and I'm getting this error:
INFO  2013-02-16 23:43:11.582 [main] Configuration error: java.lang.NoSuchMethodError: net.pms.encoders.FFMpegVideo.<init>(Lnet/pms/configuration/PmsConfiguration;)V
I'm still using Infidel's update.jar, but it works fine with 2.4.1. I guess this has to do with it being built with JDK7?
Optimus_prime
Post by Optimus_prime »
SubJunk wrote:Nice job :) By the way I'm releasing UMSBuilder 1.3 soon which will be more reliable at building
Sweet, not that i've had much trouble. ;)
kuroukage wrote:Thanks for the new build.
I'd say so, thats a plugin that requires the different update.jar?
kuroukage
Post by kuroukage »
Optimus_prime wrote:I'd say so, thats a plugin that requires the different update.jar?
I think he built it with JDK6 and that's why it's causing an issue. I'm not exactly sure. It's calling for some Java code that it doesn't like when I try to load it up with it. SubJunk would have to elaborate on what that means. I have no idea. :P
Anyways, I tried it without (the update.jar) and everything seems to be working well except I'm having a wierd issue with Channels. I think I know why though. The Youtube channel requires PMSE and I have it set to his new default to not use it, so it wont work right. I'll have to test this in a second to see if I'm right.
EDIT: Seems it's happening with your build of 2.4.2 and also with SubJunk's (the update.jar problem). I guess he changed something in the code that's causing it not to work now?
Locked
