Sony Bravia - Issues & Problems: 2.2.0 vs 2.4.2
Re: Sony Bravia - Issues & Problems: 2.2.0 vs 2.4.2
That's what the guide will show if I ever write it heh
Sorry for the delay on this Serenus, your testing is very appreciated. I have a new version for you to try: http://www.spirton.com/uploads/UMS/UMS-Serenus-2.exe
Madoka
Post by Madoka »
SubJunk,
Loving the new beta. One small cosmetic issue. When not playing anything, the "Common Transcode Settings" tab is sized correctly. When play something so that the status bar, says "Serving XXX.mp4", I get a vertical scroll bar on that page like it didn't account for the height of the status bar. The other tabs, "Mencoder" for example, do not have the vertical scroll bar. This is on a Win7 machine.
Thanks!
PS. Thanks for fixing this so fast!
Serenus
Post by Serenus »
Subjunk,
Sorry for taking forever to reply and test this, I apologize. Here's my latest testing information:
UMS 2.5.0 - Serenus 2
Anime = OK
TV Series + Subtitles = OK
TV Series - Subtitles = NOT OK
UMS 2.6.1
Anime = NOT OK
TV Series - Subtitles = OK
I have compared both BraviaEX.conf files and they are exactly the same. I am attaching both debug files, let me know if you need anything else.
[gg]_Valvrave_the_Liberator_-_01_[191CFABD] = Anime
The rest are TV series.
Again, I appreciate the time and commitment you put into this, if you want to troubleshoot online / remote session (teamviewer) let me know and we can schedule it.
Thanks man!
ums_dbg_2.6.1.zip
(28.69 KiB) Downloaded 699 times
ums_dbg_2.5.0-Serenus_2.zip
(37.08 KiB) Downloaded 755 times
Darn I forgot what I did to the Serenus 2 build :(
Can you install 2.6.2 and change the line "TranscodeVideo=MPEGPSAC3" to "TranscodeVideo=MPEGTSAC3" in BraviaEX.conf? I don't know if it will fix it but I'm interested to see what happens...
Hopefully this program will get super popular and make enough money from donations and ads so we can buy renderers for the developers so we can make them all run 100%. We can dream! :)
Serenus
Post by Serenus »
UMS 2.6.2 - TranscodeVideo=MPEGPSAC3 (Standard BraviaEX.conf)
ANIME = NOT OK - Black screen and error "Video file cannot be played"
UMS 2.6.2 - TranscodeVideo=MPEGTSAC3 (Modified BraviaEX.conf)
ANIME = NOT OK - I get sound but the screen is pitch black
TV Series + Subtitles = NOT OK - I get sound but the screen is pitch black
You rock as usual, thanks man!
ums_dbg_2.6.2_MPEGTSAC3.zip
(25.8 KiB) Downloaded 864 times
ums_dbg_2.6.2_MPEGPSAC3.zip
(25.69 KiB) Downloaded 793 times
Can you please re-test "Serenus 2" and 2.6.2 with the anime file please? This time I need the "trace" information, so can you please select "Trace" from the "Log level" dropdown on the Logs tab before playing the file? Hopefully this will tell me what to change. Thanks!
Serenus
Post by Serenus »
There you go.
ums_dbg_2.6.2_TRACE.zip
(29.3 KiB) Downloaded 745 times
ums_dbg_2.5.0_TRACE.zip
(30.89 KiB) Downloaded 790 times
Ah cool. And the last 2.6.2 version is the standard version right? Without the BraviaEX.conf modification?
Serenus
Post by Serenus »
Yup, you're right.
