Playback Impossible: Transcoded MKV!
dadish
Re: Playback Impossible: Transcoded MKV!
Post by dadish »
This was a bit weird. Tried first with UMS 2.5.1 replaced the SamsungAllshare.conf with yours started up and tried. No change same error with "File not supported" and error in mencoder at logg. Then I tried with installing (clean install ofc) UMS-Serenus-7.exe Version 3.0.0 and replacing the SamsungAllshare.conf and it worked, why it worked I can't say but it does. Logs attached as usual :D Thank you for the support.
New-Samsunallshare_conf_ums_3.0.0_dbg.zip
3.0.0 version
(53.06 KiB) Downloaded 587 times
New-Samsunallshare_conf_ums_dbg.zip
2.5.1 version
(26.68 KiB) Downloaded 595 times
Cool, how about this one? http://www.spirton.com/uploads/UMS/UMS-dadish.exe
No need to replace the .conf with this build
dadish
Post by dadish »
Works as well. One thing is that UMS did not automatically find my Samsung Tv but when I pressed the source button on the remote it found it. Otherwise everything works. Logs attached. Well done SubJunk thank you for the support.
3.0.0_dadish_ums_dbg.zip
(31.79 KiB) Downloaded 575 times
Cool! Well I put the fix into 2.6.4 so hopefully that works, or just keep using that dadish build
dadish
Post by dadish »
Ill use this for the moment, will try out the new one when it comes out to check that everything works. Yet again thank you for the support.
Alarith
Post by Alarith »
I am having the same started stopping error with my LG TV. What did you change in the conf file that made this fix possible please?
Kind regards
Ala
