MovieInfo
SharkHunter
Re: MovieInfo
Post by SharkHunter »
Added a new version of MovieInfo to http://code.google.com/p/sharkhunter-shb/downloads/list.
This time I might have gone over the top. I've added a MovieDB fetaure to MovieInfo which uses OpenSubtitles and IMDB to create a DB wher you can browse based on title,genre,cast etc.
To be able to use you must do 2 things.
1) Add "movieinfo.movieDB=true" to UMS.conf. THIS MUST BE DONE MANUALLY
2) Scan your dir(s). THIS MUST BE DONE FROM THE MOVIEINFO GUI. If you don't enter a scan path in the GUI ALL your shared folders will be scanned so beware...
Any issues should be reported.
nonolk
Re: MovieInfo
Post by nonolk »
Hello Sharkunter,
Good job, unfortunatly it just crash after adding one file in the library.
If you want, I can provide you the log if needed, but it end with memory issue with the garbage collector.
But thank you very much for your work, and I'm sure you will fix it.
Best regards,
SharkHunter
Re: MovieInfo
Yes Pls up with the logs (viewtopic.php?f=9&t=556)
It works for me so it must be some small error...
nonolk
Re: MovieInfo
Post by nonolk »
Hello Sharkhunter,
Sorry for the delay, but here is the zip file containing all the requested logs.
I hope this will help.
(13.05 KiB) Downloaded 1278 times
Best regards,
SharkHunter
Re: MovieInfo
Thx,
From the log we see
at java.lang.String.replaceAll(Unknown Source)
INFO  2013-03-12 20:29:50.669 [Library Scanner] 	at net.pms.movieinfo.plugins.IMDBPlugin.getCast(IMDBPlugin.java:149)
INFO  2013-03-12 20:29:50.669 [Library Scanner] 	at net.pms.movieinfo.FileMovieInfoVirtualFolder.gather(FileMovieInfoVirtualFolder.java:171)
INFO  2013-03-12 20:29:50.669 [Library Scanner] 	at net.pms.movieinfo.MovieDB.scanDir(MovieDB.java:315)
INFO  2013-03-12 20:29:50.669 [Library Scanner] 	at net.pms.movieinfo.MovieDB.run(MovieDB.java:338)
INFO  2013-03-12 20:29:50.669 [Library Scanner] 	at java.lang.Thread.run(Unknown Source)
which indicates that the plugin consumes LOTS of memory.
In your MOVIEINFO.conf file try and set
NumberOfActors=X
where you pick X rather small (say 7 or so) and try again.
Re: MovieInfo
It may also be that it doesn't release the memory, because usually my first lookup succeeds but the second one freezes the program
ExSport
Re: MovieInfo
Post by ExSport »
Subjunk have you tried csfd plugin only?
For me it works without problems so if you will have same problems like with imdb, problem is on your side.
If it will work OK, problem should be imdb parser only?
Re: MovieInfo
ExSport wrote:Subjunk have you tried csfd plugin only?
What's csfd?
SharkHunter
Re: MovieInfo
The only diff I see between the CSFD and IMDB is that IMDB parses out cast pics (and character name) which CSFD doesn't. This is inherited code so I'm not 100% what goes on here...
ExSport
Re: MovieInfo
Post by ExSport »
@Subjunk, MovieInfo plugin includes parser plugins like IMDB, CSFD, etc.
#Plugins=IMDB,FILMWEB,CSFD,MOVIEMETER,ALLOCINE,MYMOVIES,OFDB,FILMDELTA,SENSACINE,ONFILM,KINOPOISK
For what I asked is to disable IMDB which is problematic for you and test CSFD only which (I am sure) works correctly.
If it will work for you then problem will not be whole MovieInfo plugin but IMDB parser which can have memory leak or something else why it freezes for you.
But if CSFD will not work for you same way as IMDB, then probably problem is on your side only and not in MovieInfo plugin.
I am using MovieInfo with CSFD only for years and never spotted any memory or freezing problem so we should narrow it with this easy test 8-)
@SharkHunter: Yes, as you say, actor pics and trailers are not retrieved (but movie poster works) and also another difference is that CSFD is "czech" parser (but has no problems to parse movie title in original language) :mrgreen:
Sharkhunter, do you have similar problems with IMDB as SubJunk described? When I tested IMDB I didn't spotted anything abnormal.
