Encrypted dvd playback problem.
Re: Encrypted dvd playback problem.
Sami32, I managed!
) I installed MPlayer version 1.3, which included MEncoder and the picture went! Everything works and even very good!
Only here there is no possibility of searching the clip track. It depends on the media server, or already from my client, who sends information to the media player? But still I'm very pleased with what happened!
@Andrey I'm glad to know that you finally get it to work
I was suspecting your MPlayer/MEncoder issue, as we use an old own version, and the fact that it's known to be not too reliable but FFmpeg do not handle DVD
And all the Linux system are well known to be so different that it just no thinkable to make something work without issue on all of them
Thank you for your feedback
Yes, I'm glad for that, too. The only question that remains is how to change the aspect ratio in MEncoder. It seems to me that this encoder shows the original ratio, but I need it to be 16:9, is this possible?
Yes, normally it should have been done automatically. I never read any DVD with it, but @Nadahar recently reported like you, so it's possible that it has been broken.
You can manually add it into your renderer configuration file:
If that doesn't fill your need, delete these lines and add that one:
If it's still not as you expect, you'll need to adapt it to your need.
Please, take time to return feedback. Thank you
Hoping that helped.
KeepAspectRatio = true
KeepAspectRatioTranscoding = true
CustomMencoderOptions = -vf softskip,expand=::::1:16/9:2,scale=1283:720 -lavcopts aspect=16/9
Hoping that helped.
Yes, the first two lines worked perfectly. Only the picture after the change of sides began to show small jerks. Can this be fixed somehow, or should we wait for the next versions of the mediaserver?
Sorry, i don't understand what you mean, so i cannot help you on that. I'm not an english native so that doesn't really help.
Except if you can rephrase it or post a photo.
Ok, nothing terrible. I'm from Russia and I also use Google translator to communicate with you. I'll try to wait for new versions of the program, but for now I will use the old aspect ratio. Anyway, thank you very much - you helped me a lot!
You're welcome
Congratulation for your english anyway
Yes, Google Translate can be "weaky" in the translation, but it far better than nothing
I prefer tell you that nothing will change in the next version concerning that point. I don't think @Nadahar will modify it, as like me, he never use the DVD or ISO.
Did you tried the second option that i given you, perhaps it should give you a better result ?
Yes, I tried both functions. When the aspect ratio included - picture video is as if braking. As soon as I turn off the keep aspect ratio everything is displayed perfectly. Do you think there is any way to solve this problem?
Sorry, i don't really understand what is your issue, only that your display is not as you like.
You can ask to @SubJunk, as he is an english native, the only one by now, and the only video developper here.
To answer your question: Yes, there is a way to solve that.
But it need people that understand your issue, to give you a fix.
EDIT: What you can do, is open an issue there and explain your issue:
https://github.com/UniversalMediaServer ... ver/issues
