Problem with ums-6.7.0
Re: Problem with ums-6.7.0
I've uploaded a new "update.jar" to the same location. Please generate a new log with the updated version. It would also be nice if you could add in a couple of PNG's in the "test folder" even though they work.
Success.
Using the new update.jar file I was able to see and view the 6 image files in the "Test" folder. (2 x gif, 2 x jpg, 2 x png)
The zipped log file is attached.
- debug Log.zip
- (20.33 KiB) Downloaded 626 times
Good, that's a start.
I haven't "fixed" it as such, I've only disabled a part to compensate for "shortcomings" in the LG. Making this change permanent would break other renderers. In short, your renderer claims that it supports:
..among many other mime-types. But, this obviously isn't true as it hides images if they are of some jpeg "types" or gif. This is a "problem"/bug with the LG as far as I can see, and I'll have to figure out how to handle it without breaking other renderers.
It might take some time for me to do this, but I hope you'll be available to test again when I've implemented a more "elaborate" solution.
http-get:*:image/jpeg:*
http-get:*:image/gif:*
http-get:*:image/png:*
I will definitely be available for any further testing,
Thanks for your support.
I have just installed 6.7.2
I can report that the problem with my image files is still the same.
They do work though if I have the update.jar file in the UMS directory as in 6.7.1
No. I'm sorry about this, I specificly asked if the release could wait for me to finish this fix, but I was ignored. The update.jar will only work with 6.7.1.
No problem.
But.... update.jar works with 6.7.2 also.
It might "work", but there could potentially be problems. But, the "update.jar" will actually override the version so you will be running the exact same version that you were - the only difference is that the dependencies that's packed in "ums.jar" will be newer (and potentially conflict with the "update.jar" made for 6.7.1)
Ok. Thanks. Best I revert to 6.7.1 with update.jar then.
I've abandoned my "proper fix" and made a "quick fix" which can be found here. I'd appreciate if you could test it and report back.
