Re: Jumpy Plugin (2 Feb 2013)
updated update.jar for UMS 2.5.0/ffmpegwebvideo/pmsencoder coexistence:
- put the enclosed update.jar and ffmpeg.webfilters in your UMS program folder
- put the enclosed ffmpegwebvideo-first.groovy in your pmsencoder scripts folder
Awesome, thanks man. Appreciate the fast update.infidel wrote:updated update.jar for UMS 2.5.0/ffmpegwebvideo/pmsencoder coexistence
![Smile :)](./images/smilies/icon_e_smile.gif)
天 黒影 天
Infidelinfidel wrote:I'll see if I can implement this in a proper way in future versions, but for now you can hack it by editing plugins/jumpy/xbmc/xbmcgui.py (line 112) to another default (0=1st, 1=2nd and so on):frentemorao wrote:Is there any way of changing the default option from 0 to 1 or 2??def select(self, heading, list, autoclose=None):
"""Show a select dialog."""
print "*** dialog select ***\n%s%s" % (heading, list)
return 1
I would like to know if you are working in implementing this option in future version...
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
The future has arrived (a little late maybefrentemorao wrote:I would like to know if you are working in implementing this option in future version...![]()
- create a plain text file named xbmc.dialogs in your UMS profile folder (i.e. where UMS.conf is located).
- navigate to the dialog on the xmb, then look inside jumpy.log. and find the new-style dialog printout:
0 <<< 'Elige una opci\xc3\xb3n' ['Ver el v\xc3\xaddeo rt=0 [directo]', 'Descargar', 'A\xc3\xb1adir a favoritos', ...
- copy this one entire line as-is into xbmc.dialogs and edit the selection to be what you want:2 <<< 'Elige una opci\xc3\xb3n' ['Ver el v\xc3\xaddeo rt=0 [directo]', 'Descargar', 'A\xc3\xb1adir a favoritos', ...
- restart UMS. From now on jumpy will choose your selection whenever it sees this dialog in this specific addon.
The JUMPY plugin needs to be enhanced so it can read the XBMC Navi-x plugin, and XBMC Movie section. At this time JUMPY only reads the XBMC Video Addons.
I am afraid it doesn't work (or I cannot make it work)infidel wrote: The future has arrived (a little late maybe). Install the update below and:
0 <<< Elige una opción , ['Ver el v\xc3\xaddeo rt=0 [directo]', 'Descargar', 'A\xc3\xb1adir a favoritos', ... ]- copy this one entire line as-is into xbmc.dialogs and edit the selection to be what you want:
2 <<< Elige una opción , ['Ver el v\xc3\xaddeo rt=0 [directo]', 'Descargar', 'A\xc3\xb1adir a favoritos', ... ]- restart UMS. From now on jumpy will choose your selection whenever it sees this dialog.
I have created the plain text file in my UMS folder (attached), have copied the new-style dialog printout from jumpy.log and have pasted and edited the selection chosing 2 instead of 0 to watch the video in 480p:
2 <<< Elige una opción , ['Ver el v\xc3\xaddeo 240p [vk]', 'Ver el v\xc3\xaddeo 360p [vk]', 'Ver el v\xc3\xaddeo 480p [vk]', 'Ver el v\xc3\xaddeo 720p [vk]', 'Descargar', 'A\xc3\xb1adir a favoritos', 'A\xc3\xb1adir a biblioteca', 'A\xc3\xb1adir a lista de descargas', 'Enviar a jDownloader', 'Buscar trailer']
I would like to point out that it works manually according to this post: viewtopic.php?f=6&t=288&start=150#p3105
However, I wonder if the dialog could be shown on the TV/PS3...
This option would be the most appropriate one because, depending on the addon, I need to change the selection (for instance, for tvalacarta addon, selection 0 will be always the correct one... nevertheless, for pelisalacarta addon, the selection would vary depending on the quality of the video...)
Hi umsfan,umsfan wrote:The JUMPY plugin needs to be enhanced so it can read the XBMC Navi-x plugin, and XBMC Movie section. At this time JUMPY only reads the XBMC Video Addons.
- I will probably add support for xbmc 'script' type plugins such as Navi-x in the future, but I can't promise exactly when
. The Channels plugin already supports Navi-x, have you tried it?
- I don't plan to support the xbmc movie section, there's already a plugin for that.
frentemorao wrote:I am afraid it doesn't work (or I cannot make it work)
Special characters again: opción worked in linux but not windowsfrentemorao wrote:depending on the addon, I need to change the selection
Regarding your general question, it's possible to present dialogs as folders on the xmb and let you choose, but it doesn't work in a consistent way among renderers and can become annoying very fast.
Hi infidel:
Thanks for responding to my suggestion. I am keenly waiting for the XBMC Navi-x plugin. I have been using the Navi-x with Channels plugin for a while but it is not very much stable. Also 1Channel, Icefilms, and Movie2k plugins don't work all the time. There is an issue with the audio-video synchronization. Sometime video is faster then the audio, and sometime video is frozen while playing. I have tried your new FFmpeg update plugin jar alongwith pmsencoder that supports Navi-x channels video. I see some improvements since it now allows to play live tv channels in Navi-x. On the other side, I still see Jumpy as stable and better plugin since I can play most of the xbmc plugins like 1channel, Hulu, Icefilms, Jtv, veetle, and youtube. However, this is my personal opinion. I have am using UMS 2.5 that I have installed using your UMS Builder 1.4 release. I have installed it on my laptop, and I am playing media on my Verismo/Jadoo TV IPTV box.
Regards,
umsfan.
Regards,
umsfan.
