Channels Plugin
Larkin
Re: Channels Plugin
Post by Larkin »
I can not watch my youtube subscriptions with UMS 3.1. They appear as a selection but my renderer (Bravia 5500) fails with error message when trying to play them. I do not use pmsencoder.
It seems the file name is incorrectly handed to ffmpeg.
TRACE 2013-11-23 21:25:41.911 [New I/O worker #6] Sent to socket: Content-Length: 14417
TRACE 2013-11-23 21:25:41.911 [New I/O worker #6] Sent to socket: Content-Type: text/xml; charset="utf-8"
TRACE 2013-11-23 21:25:41.911 [New I/O worker #6] Sent to socket: Server: Windows_7-x86-6.1, UPnP/1.0, UMS/3.1.0
TRACE 2013-11-23 21:25:42.161 [New I/O worker #7] Asked stream chunk : TimeRange [start=null, end=null] of Fnatic EU vs 4FC - BigPoint Battle DOTA 2 - Sheever and player FFmpeg Web Video
DEBUG 2013-11-23 21:25:42.161 [New I/O worker #7] Starting transcode/remux of Fnatic EU vs 4FC - BigPoint Battle DOTA 2 - Sheever with media info: container: null, bitrate: 0, size: 0, video codec: null, duration: null, width: 0, height: 0, frame rate: null, muxing mode: null, mime type: null
TRACE 2013-11-23 21:25:42.161 [New I/O worker #7] Searching for a match for: null with eng and off
TRACE 2013-11-23 21:25:42.176 [New I/O worker #7] Searching for a match for: null with * and eng
TRACE 2013-11-23 21:25:42.176 [New I/O worker #7] Searching for a match for: null with * and und
TRACE 2013-11-23 21:25:42.176 [New I/O worker #7] Looking for a subtitle track with lang: ger
TRACE 2013-11-23 21:25:42.176 [New I/O worker #7] Looking for a subtitle track with lang: jpn
TRACE 2013-11-23 21:25:42.176 [New I/O worker #7] Looking for a subtitle track with lang: eng
TRACE 2013-11-23 21:25:42.176 [New I/O worker #7] Looking for a subtitle track with lang: und
DEBUG 2013-11-23 21:25:42.176 [New I/O worker #7] Creating pipe \\.\pipe\ffmpegwebvideo_41_1385238342176
DEBUG 2013-11-23 21:25:42.192 [Thread-18] Waiting for pipe connection \\.\pipe\ffmpegwebvideo_41_1385238342176
DEBUG 2013-11-23 21:25:42.504 [ffmpeg.exe-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -y -loglevel info -threads 3 -i Das -vf scale=1280:720,setdar=4/3,pad=1280:720 -threads 3 -c:a ac3 -c:v mpeg2video -f vob -bufsize 1835000 -maxrate 499000000 -g 5 -q:v 1 -qmin 2 -qmax 3 -q:a 3 \\.\pipe\ffmpegwebvideo_41_1385238342176
DEBUG 2013-11-23 21:25:42.504 [ffmpeg.exe-1] Reading pipe: \\.\pipe\ffmpegwebvideo_41_1385238342176
DEBUG 2013-11-23 21:25:42.613 [Thread-20] ffmpeg version N-53724-g716dbc7 Copyright (c) 2000-2013 the FFmpeg developers
DEBUG 2013-11-23 21:25:42.613 [Thread-20]   built on May 31 2013 23:33:02 with gcc 4.8.0 (GCC)
DEBUG 2013-11-23 21:25:42.613 [Thread-20]   configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
DEBUG 2013-11-23 21:25:42.613 [Thread-20]   libavutil      52. 34.100 / 52. 34.100
DEBUG 2013-11-23 21:25:42.613 [Thread-20]   libavcodec     55. 12.102 / 55. 12.102
DEBUG 2013-11-23 21:25:42.613 [Thread-20]   libavformat    55.  8.102 / 55.  8.102
DEBUG 2013-11-23 21:25:42.613 [Thread-20]   libavdevice    55.  2.100 / 55.  2.100
DEBUG 2013-11-23 21:25:42.613 [Thread-20]   libavfilter     3. 73.100 /  3. 73.100
DEBUG 2013-11-23 21:25:42.613 [Thread-20]   libswscale      2.  3.100 /  2.  3.100
DEBUG 2013-11-23 21:25:42.613 [Thread-20]   libswresample   0. 17.102 /  0. 17.102
DEBUG 2013-11-23 21:25:42.613 [Thread-20]   libpostproc    52.  3.100 / 52.  3.100
DEBUG 2013-11-23 21:25:42.613 [Thread-20] Das: No such file or directory
(40.86 KiB) Downloaded 885 times
tachav
Re: Channels Plugin
Post by tachav »
hello ppl. i'm new to ums and this plugin. I installed ums, when i tried to install channels plugin nothing happened. rr ums, and in the log file there was end error during processing pmsencoder. reinstalled many times, nothing happened. I removed pmsencoder from plugins directory, the channel plugin installed succesfully, but when i select icefilms and go to a tv show the only available source in 180upload which never plays (i think it has capcha). I tried from ps3 and an lg smart tv, the result was the same. When i tried the same episode from either the webpage or xbmc, i saw multiple sources. Any suggestions?
SharkHunter
Re: Channels Plugin
Post by SharkHunter »
tachav - IceFilms hasn't been updated for a while. So it most probably doesn't work. For example 180upload was the only one I thought was good enough before so thats why you only see 180 links.
Larkin - pls enable Channels debug as well (channels.debug = true in UMS.conf or use the gui) and redo your test and upload the new logs.
tachav
Re: Channels Plugin
Post by tachav »
thanks for the reply sharkhunter. I suppose the same thing happens for 1channel also? cause i can't get any links to that
SharkHunter
Re: Channels Plugin
tachav - most likely yes
Larkin
Re: Channels Plugin
Post by Larkin »
SharkHunter wrote: Larkin - pls enable Channels debug as well (channels.debug = true in UMS.conf or use the gui) and redo your test and upload the new logs.
Ok. Here are the logs with channels debug.
(69.38 KiB) Downloaded 894 times
SharkHunter
Re: Channels Plugin
Larkin - You get an error "Das System kann den angegebenen Pfad nicht finden" I suspect that your youtube-dl.bat script is not found. Channels looks in "C:\Program Files (x86)\Universal Media Server\scripts" I suspect that it should be C:\Program Files (x86)\Universal Media Server\extras\scripts
so modify the line
youtube-dl.path = C:\\Program Files (x86)\\Universal Media Server\\scripts
to
youtube-dl.path = C:\\Program Files (x86)\\Universal Media Server\\extras\\scripts
modify this as well
pmsencoder.script.directory = C:\\Program Files (x86)\\Universal Media Server\\scripts
to
pmsencoder.script.directory = C:\\Program Files (x86)\\Universal Media Server\\extras\\scripts
Larkin
Re: Channels Plugin
Post by Larkin »
youtube-dl.bat is located in "c:\Program Files (x86)\Universal Media Server\scripts\" and there is no folder extras\scripts !
I took a look at youtube-dl.bat and it includes the line
extras\Python27\python.exe %str% "-g" %1
Two problems here :
1. I had no python27 folder in extras, just a file pepy.zip. I unzipped in hope that it will work with a valid python27 folder but still it fails.
2. It seems that "extras\Python27\python.exe ..." is causing the error message using a relativ path which is not found.
The current structure is
extras\python27\python.exe
scripts\youtube-dll.bat
I made no manual install.
What shall I try next ? Thanks for trying to help.
SharkHunter
Re: Channels Plugin
Remove the pepy.zip file and reinstall channels. It might have been an old failed install the does bad stuff.
Larkin
Re: Channels Plugin
Post by Larkin »
I removed pepy.zip and reinstalled channels with the gui. Now I have a new pepy.zip but it is still unpacked and youtube is of course not working as youtube-dl.bat is asking for python.exe which does not exist. I installed in win7 admin mode.
I unzipped pepy and tried again but it still fails.
Started playing Natus Vincere vs Team DK - Game 3 - Semifinals - MLG Columbus 2013 on your Sony Bravia 5500
DEBUG 2013-11-29 11:25:00.342 [StartPlaying Event] The full filename of which is: extras\Python27\python.exe: and the address of the renderer is: 192.168.2.153
I guess the full filnename is not just extras\Python27\python.exe:
What now ?
(48.77 KiB) Downloaded 873 times
