picture problem
Re: picture problem
I've made a special build with extra logging in the code that makes the decisions about which image profiles to offer here: http://superbum.org/downloads/UMS-setup ... ogging.exe
Please install this and generate new debug files.
Re: picture problem
I hope this will help...
But i didn't make a clean installation!
- (102.03 KiB) Downloaded 381 times
Re: picture problem
"Clean installation" doesn't matter unless you're superstitious
This helped a lot, I think I found the bug: https://github.com/UniversalMediaServer ... 2883-L2888
It's not so easy to see, but we/I (I made this code ) check if PNG_LRG is supported before adding JPEG_LRG. A lot of renderers support PNG as well, and they will have no issue, but those that only supports JPEG and NOT the JPEG_RES_H_V form will experience this bug.
Re: picture problem
I've built a new version, it will be finished uploading in about 8 minutes: http://superbum.org/downloads/UMS-setup-imagefix.exe
Retest plx...
Retest plx...
Re: picture problem
Of course i'm superstitious - I'm a Windows user, making lots of "clean OS installations" in the past...
I've just tested your new build and the result is marvelous: Now all photos are sized in the correct resution!
One word to your support: I haven't experienced anything like that yet. - It's absolutely incredible for me!
In the past i bought some commercial software without any (helpful) support...
And here someone takes care of quickly and competently.
Many THANKS for these fast fix. You are an oasis in the wasteland of software support!
Please go on with it...
Re: picture problem
Good to hear and thank you. Not all users agree though
I will make sure the fix is in the next version. Until then you can just use the test version as it's identical with 7.0.0 except for the extra logging. The extra logging is only active when "trace" is activated anyway, so it won't have any effect during normal use.
The fix is submitted here: https://github.com/UniversalMediaServer ... /pull/1474
