UMSBuilderV2: build any UMS branch
Re: UMSBuilderV2: build any UMS branch
Update: V2.6 - fix problem chars in pr titles on Windows + ensure entire 'Show all' list is visible.
Thanks!infidel wrote:Update: V2.6 - fix problem chars in pr titles on Windows + ensure entire 'Show all' list is visible.
Update: V2.7 - support new ums build changes + linux fixes
Hello infidel
Tested latest v2.7 with UMSbilder v1.9 and some parts doesn't work:
Unfortunately I had no time to check script so reporting
EDIT:
OK, checked it and curl,grep and sed is unknown.
Your script generates this path with help of registry:
But latest GIT installation creates:
Using 64bit OS
Windows -- Build the master branch -- working
Windows -- Choose another branch -- immediately exit the script
Windows -- Show all -- 6.0.0 -- working
EDIT:
C:\Program Files\Git\Bin
C:\Program Files\Git\usr\bin
thx ExSport, a full report as alwaysExSport wrote:But latest GIT installation creates:Code: Select all
Update: V2.8 - support new git-for-windows paths
Fast as always!
Thx!
Thx!
+1 Thx @Infidel for making soooo easy to quickly build UMS!ExSport wrote:Fast as always!![]()
Thx!
Question: the packing of the installer (.exe) file seems to take a lot of time and resources. Is there any way to just end the process on generating UMS.jar? (ie skipping the MAKENSIS stage for quick features testing on some other branches)
I notice there's a compile option but the final .jar is not generated if option applied.
Thx, Wolf
Thx, Wolf
This has always been one of my pet peeves with building PMS/UMS, that there's no 'jar' target in pom.xml, tho obviously it hasn't bothered me enough to do anything about itWolfgan wrote:Question: the packing of the installer (.exe) file seems to take a lot of time and resources. Is there any way to just end the process on generating UMS.jar?
My own hacky solution is to just press CTRL-C and abort the build when the process enters the nsis phase, it doesn't harm anything.
EDIT: Feels like deja vu
