Does UMS 4.0 work with the PS4?
- SharkHunter
- Developer
Re: Does UMS 4.0 work with the PS4?
Yes I'll take a new haul of mp4 (again) but so far it hasn't been close. It is tricky to live transcode to mp4
- SharkHunter
- Developer
It looks like infidel found some cool stuff that might work. Will test tonight...
Just wondering if you had any luck with the stuff infidel pointed out?SharkHunter wrote:It looks like infidel found some cool stuff that might work. Will test tonight...
- SharkHunter
- Developer
In short it didn't improve the situation.paulinacio1991 wrote:Just wondering if you had any luck with the stuff infidel pointed out?SharkHunter wrote:It looks like infidel found some cool stuff that might work. Will test tonight...
Any change with the latest firmware update? I am guessing no but figured I would ask.
I don't know whether this thread is still active. I fixed some issues in my https://github.com/derolf/transcoder
I am running this quite successfully on a Samsung TV to watch recordings and videos. The TV can play everything, so I just use copy-codecs.
dero
dero
