Channels Announce (13-11-11)
SharkHunter
Re: Channels Announce (13-03-30)
Post by SharkHunter »
Here is a new long awaited 2.20 of Channels. It makes use of more url resolvers and resume functionallity plus a whole bunch of misc bugs.
Download here https://code.google.com/p/sharkhunter-s ... loads/list
TheRec
Re: Channels Announce (13-05-17)
Post by TheRec »
Thanks for the update.
The pmsencoder download/install still fails.
But now it's not even possible to download "pmsencoder-1.6.3.jar" manually and place it in the "plugins" directory... so it's impossible to install the pluging through the "Plugins" tab... also in this tab the version is still "2.19" for Channels.
DEBUG 2013-05-17 23:18:03.473 [Thread-21] fetch file http://sharkhunter-shb.googlecode.com/files/tv_plug_219.jar
DEBUG 2013-05-17 23:18:03.473 [Thread-21] fetch file http://dl.bintray.com/content/chocolateboy/PMS/pmsencoder/pmsencoder-1.6.3.jar?direct
DEBUG 2013-05-17 23:18:03.993 [Thread-21] An error occurred when trying to install the plugin: Channels
DEBUG 2013-05-17 23:18:03.993 [Thread-21] Full error: java.io.FileNotFoundException: plugins\pmsencoder-1.6.3.jar?direct (The filename, directory name, or volume label syntax is incorrect)
(The same error that I've mentioned in my previous posts which didn't get any answer yet).
SharkHunter
TheRec wrote:Thanks for the update.
SubJunk needs to update the install data which he'll do shortly...
Should be fixed now, sorry about that
TheRec
Post by TheRec »
Thanks, the download part is working now, all the files are downloaded correctly (although I had to click "Download and Install selected plugin" a second time as it failed while downloading one of the /scripts, but on second try it worked fine).
After downloading the files it does not automatically launch the install of Channels and also it downloaded the 2.19 version (which seems normal as it is still the version showing in the plugins list), so I've manually downloaded the 2.20 .jar and placed it in the plugins directory (and deleted the 2.19 which was downloaded through the GUI). Then I've restarted UMS (so that the "Channels" button would show under the installed plugins), and used the "Install/Update" button from the Channels GUI. Everything went fine without any error in the log. But when I try to play any video from the YouTube channel my renderer says it is unable to open the video instantly. The related Trace log in UMS is the following:
TRACE 2013-05-22 09:12:18.700 [New I/O server boss #5] Creating new pipeline
TRACE 2013-05-22 09:12:18.910 [New I/O worker #2] Opened request handler on socket /10.0.0.7:46420
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] Calling SetThreadExecutionState ES_SYSTEM_REQUIRED
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] Request: HTTP/1.1 : GET : get/0$6$37$4$1$2/Red+vs.+Blue+S8+Tex+fights+Reds+and+Blues+in+awesome+action+sequence
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] Matched media renderer "Android" based on address /10.0.0.7
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] Received on socket: Connection: close
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] Received on socket: Host: 10.0.0.2:5001
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] Received on socket: Icy-MetaData: 1
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] Received on socket: Range: bytes=0-
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] Received on socket: User-Agent: (null)
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] Recognized media renderer: Android
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] HTTP: get/0$6$37$4$1$2/Red+vs.+Blue+S8+Tex+fights+Reds+and+Blues+in+awesome+action+sequence / 0--1
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] discover 0 refresh forced: false
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] discover 0$6 refresh forced: false
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] discover 0$6$37 refresh forced: false
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] discover 0$6$37$4 refresh forced: false
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] discover 0$6$37$4$1 refresh forced: false
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] cms getinp/2 scrape com.sharkhunter.channel.ChannelMedia@6dca3565 url The
TRACE 2013-05-22 09:12:18.911 [New I/O worker #2] Asked stream chunk : TimeRange [start=null, end=null] of Red vs. Blue S8 Tex fights Reds and Blues in awesome action sequence and player null
ERROR 2013-05-22 09:12:18.912 [New I/O worker #2] There is no inputstream to return for Red vs. Blue S8 Tex fights Reds and Blues in awesome action sequence
TRACE 2013-05-22 09:12:18.913 [New I/O worker #2] Sent to socket: Content-Length: 0
TRACE 2013-05-22 09:12:18.913 [New I/O worker #2] Sent to socket: Server: Windows_Server_2008_R2-amd64-6.1, UPnP/1.0, UMS/3.0.0-a1
If I try playing a video from the "ZDF" Channel it works (only in VLC though, my other video players apps on my Android device do not seems to be able to decode the stream).
TRACE 2013-05-22 09:23:24.560 [New I/O server boss #5] Creating new pipeline
TRACE 2013-05-22 09:23:24.767 [New I/O worker #1] Opened request handler on socket /10.0.0.7:46431
TRACE 2013-05-22 09:23:24.767 [New I/O worker #1] Request: HTTP/1.1 : GET : get/0$6$39$3$2$3/TV+Noir+mit+Boy+und+Tex+%281%29
TRACE 2013-05-22 09:23:24.767 [New I/O worker #1] Matched media renderer "Android" based on address /10.0.0.7
TRACE 2013-05-22 09:23:24.767 [New I/O worker #1] Received on socket: Connection: close
TRACE 2013-05-22 09:23:24.767 [New I/O worker #1] Received on socket: Host: 10.0.0.2:5001
TRACE 2013-05-22 09:23:24.767 [New I/O worker #1] Received on socket: Icy-MetaData: 1
TRACE 2013-05-22 09:23:24.768 [New I/O worker #1] Received on socket: Range: bytes=0-
TRACE 2013-05-22 09:23:24.768 [New I/O worker #1] Received on socket: User-Agent: (null)
TRACE 2013-05-22 09:23:24.768 [New I/O worker #1] Recognized media renderer: Android
TRACE 2013-05-22 09:23:24.768 [New I/O worker #1] HTTP: get/0$6$39$3$2$3/TV+Noir+mit+Boy+und+Tex+%281%29 / 0--1
TRACE 2013-05-22 09:23:24.768 [New I/O worker #1] discover 0 refresh forced: false
TRACE 2013-05-22 09:23:24.768 [New I/O worker #1] discover 0$6 refresh forced: false
TRACE 2013-05-22 09:23:24.768 [New I/O worker #1] discover 0$6$39 refresh forced: false
TRACE 2013-05-22 09:23:24.768 [New I/O worker #1] discover 0$6$39$3 refresh forced: false
TRACE 2013-05-22 09:23:24.768 [New I/O worker #1] discover 0$6$39$3$2 refresh forced: false
TRACE 2013-05-22 09:23:24.768 [New I/O worker #1] cms getinp/2 scrape com.sharkhunter.channel.ChannelMedia@96b86ee url null
TRACE 2013-05-22 09:23:24.817 [New I/O worker #1] Matched format FFMPEG.WEB to "mms://a1014.v1252931.c125293.g.vm.akamaistream.net/7/1014/125293/v0001/wm.od.origin.zdf.de.gl-systemhaus.de/none/zdf/11/09/110909_tvnoir_tvn_vh.wmv"
TRACE 2013-05-22 09:23:24.817 [New I/O worker #1] Asked stream chunk : TimeRange [start=null, end=null] of TV Noir mit Boy und Tex (1) and player FFmpeg Web Video
INFO  2013-05-22 09:23:24.817 [New I/O worker #1] Starting transcode/remux of TV Noir mit Boy und Tex (1)
DEBUG 2013-05-22 09:23:24.819 [New I/O worker #1] Creating pipe \\.\pipe\ffmpegwebvideo_39_1369207404818
DEBUG 2013-05-22 09:23:24.824 [Thread-20] Waiting for pipe connection \\.\pipe\ffmpegwebvideo_39_1369207404818
DEBUG 2013-05-22 09:23:25.124 [ffmpeg.exe-1] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg.exe" -y -loglevel info -threads 2 -i mmsh://a1014.v1252931.c125293.g.vm.akamaistream.net/7/1014/125293/v0001/wm.od.origin.zdf.de.gl-systemhaus.de/none/zdf/11/09/110909_tvnoir_tvn_vh.wmv -threads 2 -c:a ac3 -c:v mpeg2video -f vob -q:v 3 -q:a 3 \\.\pipe\ffmpegwebvideo_39_1369207404818
DEBUG 2013-05-22 09:23:25.125 [ffmpeg.exe-1] Reading pipe: \\.\pipe\ffmpegwebvideo_39_1369207404818
TRACE 2013-05-22 09:23:25.146 [ffmpeg.exe-1] Successfully initialized buffer to 52,428,800 bytes.
DEBUG 2013-05-22 09:23:25.146 [ffmpeg.exe-1] Attaching thread: ffmpeg.exe-1
DEBUG 2013-05-22 09:23:25.147 [Thread-22] ffmpeg version N-52233-gee94362 Copyright (c) 2000-2013 the FFmpeg developers
DEBUG 2013-05-22 09:23:25.147 [Thread-22]   built on Apr 18 2013 02:50:33 with gcc 4.8.0 (GCC)
DEBUG 2013-05-22 09:23:25.147 [Thread-22]   configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libilbc --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
DEBUG 2013-05-22 09:23:25.147 [Thread-22]   libavutil      52. 26.100 / 52. 26.100
DEBUG 2013-05-22 09:23:25.147 [Thread-22]   libavcodec     55.  2.100 / 55.  2.100
DEBUG 2013-05-22 09:23:25.147 [Thread-22]   libavformat    55.  2.100 / 55.  2.100
DEBUG 2013-05-22 09:23:25.147 [Thread-22]   libavdevice    55.  0.100 / 55.  0.100
DEBUG 2013-05-22 09:23:25.147 [Thread-22]   libavfilter     3. 56.103 /  3. 56.103
DEBUG 2013-05-22 09:23:25.147 [Thread-22]   libswscale      2.  2.100 /  2.  2.100
DEBUG 2013-05-22 09:23:25.147 [Thread-22]   libswresample   0. 17.102 /  0. 17.102
DEBUG 2013-05-22 09:23:25.147 [Thread-22]   libpostproc    52.  3.100 / 52.  3.100
TRACE 2013-05-22 09:23:25.174 [Timer-4] buffered: 0 bytes / inputs: 0
TRACE 2013-05-22 09:23:25.324 [New I/O worker #1] Sleeping for 6000 milliseconds
DEBUG 2013-05-22 09:23:25.433 [Thread-22] [wmv3 @ 020b0bc0] Extra data: 8 bits left, value: 0
DEBUG 2013-05-22 09:23:27.000 [Thread-22] Guessed Channel Layout for  Input Stream #0.0 : stereo
DEBUG 2013-05-22 09:23:27.000 [Thread-22] Input #0, asf, from 'mmsh://a1014.v1252931.c125293.g.vm.akamaistream.net/7/1014/125293/v0001/wm.od.origin.zdf.de.gl-systemhaus.de/none/zdf/11/09/110909_tvnoir_tvn_vh.wmv':
DEBUG 2013-05-22 09:23:27.000 [Thread-22]   Metadata:
DEBUG 2013-05-22 09:23:27.000 [Thread-22]     WMFSDKNeeded    : 0.0.0.0000
DEBUG 2013-05-22 09:23:27.000 [Thread-22]     WMFSDKVersion   : 12.0.7600.16385
DEBUG 2013-05-22 09:23:27.000 [Thread-22]     IsVBR           : 0
DEBUG 2013-05-22 09:23:27.000 [Thread-22]     artist          : ZDF
DEBUG 2013-05-22 09:23:27.000 [Thread-22]     copyright       : (c) 2011 ZDF
DEBUG 2013-05-22 09:23:27.000 [Thread-22]   Duration: 00:43:53.39, start: 0.000000, bitrate: N/A
DEBUG 2013-05-22 09:23:27.001 [Thread-22]     Stream #0:0: Audio: wmav2 (a[1][0][0] / 0x0161), 44100 Hz, stereo, fltp, 192 kb/s
DEBUG 2013-05-22 09:23:27.001 [Thread-22]     Stream #0:1: Video: wmv3 (Main) (WMV3 / 0x33564D57), yuv420p, 688x384, 1400 kb/s, 25 tbr, 1k tbn, 1k tbc
DEBUG 2013-05-22 09:23:27.002 [Thread-20] Result of \\.\pipe\ffmpegwebvideo_39_1369207404818 : true
DEBUG 2013-05-22 09:23:27.006 [Thread-22] [wmv3 @ 020b0bc0] Extra data: 8 bits left, value: 0
DEBUG 2013-05-22 09:23:27.006 [Thread-22] [vob @ 0219f9a0] VBV buffer size not set, muxing may fail
DEBUG 2013-05-22 09:23:27.006 [Thread-22] Output #0, vob, to '\\.\pipe\ffmpegwebvideo_39_1369207404818':
DEBUG 2013-05-22 09:23:27.006 [Thread-22]   Metadata:
DEBUG 2013-05-22 09:23:27.006 [Thread-22]     WMFSDKNeeded    : 0.0.0.0000
DEBUG 2013-05-22 09:23:27.006 [Thread-22]     WMFSDKVersion   : 12.0.7600.16385
DEBUG 2013-05-22 09:23:27.007 [Thread-22]     IsVBR           : 0
DEBUG 2013-05-22 09:23:27.007 [Thread-22]     artist          : ZDF
DEBUG 2013-05-22 09:23:27.007 [Thread-22]     copyright       : (c) 2011 ZDF
DEBUG 2013-05-22 09:23:27.007 [Thread-22]     encoder         : Lavf55.2.100
DEBUG 2013-05-22 09:23:27.007 [Thread-22]     Stream #0:0: Video: mpeg2video, yuv420p, 688x384, q=2-31, 200 kb/s, 90k tbn, 25 tbc
DEBUG 2013-05-22 09:23:27.007 [Thread-22]     Stream #0:1: Audio: ac3, 44100 Hz, stereo, fltp, 192 kb/s
DEBUG 2013-05-22 09:23:27.007 [Thread-22] Stream mapping:
DEBUG 2013-05-22 09:23:27.007 [Thread-22]   Stream #0:1 -> #0:0 (wmv3 -> mpeg2video)
DEBUG 2013-05-22 09:23:27.007 [Thread-22]   Stream #0:0 -> #0:1 (wmav2 -> ac3)
DEBUG 2013-05-22 09:23:27.007 [Thread-22] Press [q] to stop, [?] for help
TRACE 2013-05-22 09:23:27.174 [Timer-4] buffered: 0 bytes / inputs: 0
DEBUG 2013-05-22 09:23:27.626 [Thread-22] frame=   55 fps=0.0 q=3.0 size=     262kB time=00:00:02.12 bitrate=1012.4kbits/s
DEBUG 2013-05-22 09:23:28.276 [Thread-22] frame=   72 fps= 57 q=3.0 size=     324kB time=00:00:02.80 bitrate= 947.9kbits/s
DEBUG 2013-05-22 09:23:28.876 [Thread-22] frame=   87 fps= 47 q=3.0 size=     442kB time=00:00:03.40 bitrate=1065.0kbits/s
TRACE 2013-05-22 09:23:29.174 [Timer-4] buffered: 331,776 bytes / inputs: 0
DEBUG 2013-05-22 09:23:29.488 [Thread-22] frame=  102 fps= 41 q=3.0 size=     546kB time=00:00:04.00 bitrate=1118.2kbits/s
DEBUG 2013-05-22 09:23:30.141 [Thread-22] frame=  119 fps= 38 q=3.0 size=     598kB time=00:00:04.68 bitrate=1046.8kbits/s
DEBUG 2013-05-22 09:23:30.756 [Thread-22] frame=  134 fps= 36 q=3.0 size=     704kB time=00:00:05.28 bitrate=1092.3kbits/s
TRACE 2013-05-22 09:23:31.174 [Timer-4] buffered: 659,456 bytes / inputs: 0
TRACE 2013-05-22 09:23:31.324 [New I/O worker #1] Finished sleeping for 6000 milliseconds
INFO  2013-05-22 09:23:31.325 [StartPlaying Event] Started playing TV Noir mit Boy und Tex (1) on your Android
DEBUG 2013-05-22 09:23:31.325 [StartPlaying Event] The full filename of which is: mms://a1014.v1252931.c125293.g.vm.akamaistream.net/7/1014/125293/v0001/wm.od.origin.zdf.de.gl-systemhaus.de/none/zdf/11/09/110909_tvnoir_tvn_vh.wmv and the address of the renderer is: 10.0.0.7
TRACE 2013-05-22 09:23:31.326 [New I/O worker #1] Using chunked response. Sending 786432 bytes.
TRACE 2013-05-22 09:23:31.326 [New I/O worker #1] Suspend Read: readCount=0 / writeCount=786432
DEBUG 2013-05-22 09:23:31.375 [Thread-22] frame=  149 fps= 34 q=3.0 size=     828kB time=00:00:05.88 bitrate=1153.6kbits/s
DEBUG 2013-05-22 09:23:32.005 [Thread-22] frame=  166 fps= 33 q=3.0 size=     886kB time=00:00:06.56 bitrate=1106.4kbits/s
DEBUG 2013-05-22 09:23:32.628 [Thread-22] frame=  181 fps= 32 q=3.0 size=    1022kB time=00:00:07.16 bitrate=1169.3kbits/s
TRACE 2013-05-22 09:23:33.174 [Timer-4] buffered: 972,800 bytes / inputs: 1
DEBUG 2013-05-22 09:23:33.235 [Thread-22] frame=  196 fps= 31 q=3.0 size=    1158kB time=00:00:07.76 bitrate=1222.5kbits/s
TRACE 2013-05-22 09:23:33.326 [New I/O worker #1] Resume Read: readCount=0 / writeCount=1185792
TRACE 2013-05-22 09:23:33.327 [New I/O worker #1] Sent to socket: Accept-Ranges: bytes
TRACE 2013-05-22 09:23:33.327 [New I/O worker #1] Sent to socket: Connection: keep-alive
TRACE 2013-05-22 09:23:33.327 [New I/O worker #1] Sent to socket: Content-Range: bytes 0-786431/*
TRACE 2013-05-22 09:23:33.327 [New I/O worker #1] Sent to socket: Content-Type: video/mpeg
TRACE 2013-05-22 09:23:33.327 [New I/O worker #1] Sent to socket: Server: Windows_Server_2008_R2-amd64-6.1, UPnP/1.0, UMS/3.0.0-a1
TRACE 2013-05-22 09:23:33.451 [New I/O worker #1] Ready to Stop: true
TRACE 2013-05-22 09:23:33.466 [New I/O server boss #5] Creating new pipeline
TRACE 2013-05-22 09:23:33.710 [New I/O worker #2] Opened request handler on socket /10.0.0.7:46432
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] Request: HTTP/1.1 : GET : get/0$6$39$3$2$3/TV+Noir+mit+Boy+und+Tex+%281%29
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] Matched media renderer "Android" based on address /10.0.0.7
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] Received on socket: Connection: close
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] Received on socket: Host: 10.0.0.2:5001
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] Received on socket: Icy-MetaData: 1
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] Received on socket: Range: bytes=586432-
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] Received on socket: User-Agent: (null)
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] Recognized media renderer: Android
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] HTTP: get/0$6$39$3$2$3/TV+Noir+mit+Boy+und+Tex+%281%29 / 586432--1
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] discover 0 refresh forced: false
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] discover 0$6 refresh forced: false
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] discover 0$6$39 refresh forced: false
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] discover 0$6$39$3 refresh forced: false
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] discover 0$6$39$3$2 refresh forced: false
TRACE 2013-05-22 09:23:33.711 [New I/O worker #2] cms getinp/2 scrape com.sharkhunter.channel.ChannelMedia@96b86ee url mms://a1014.v1252931.c125293.g.vm.akamaistream.net/7/1014/125293/v0001/wm.od.origin.zdf.de.gl-systemhaus.de/none/zdf/11/09/110909_tvnoir_tvn_vh.wmv
TRACE 2013-05-22 09:23:33.712 [New I/O worker #2] Asked stream chunk : ByteRange [start=586432, end=-1] of TV Noir mit Boy und Tex (1) and player FFmpeg Web Video
TRACE 2013-05-22 09:23:33.712 [New I/O worker #2] Ready to Stop: false
DEBUG 2013-05-22 09:23:33.712 [New I/O worker #2] Setting InputStream new position to: 586,432
TRACE 2013-05-22 09:23:33.712 [New I/O worker #2] Using chunked response. Sending 1185792 bytes.
TRACE 2013-05-22 09:23:33.712 [New I/O worker #2] Suspend Read: readCount=586432 / writeCount=1185792
DEBUG 2013-05-22 09:23:33.875 [Thread-22] frame=  212 fps= 31 q=3.0 size=    1288kB time=00:00:08.40 bitrate=1256.1kbits/s
DEBUG 2013-05-22 09:23:34.485 [Thread-22] frame=  228 fps= 31 q=3.0 size=    1360kB time=00:00:09.04 bitrate=1232.4kbits/s
DEBUG 2013-05-22 09:23:35.095 [Thread-22] frame=  243 fps= 30 q=3.0 size=    1534kB time=00:00:09.64 bitrate=1303.6kbits/s
TRACE 2013-05-22 09:23:35.174 [Timer-4] buffered: 984,384 bytes / inputs: 1
DEBUG 2013-05-22 09:23:35.754 [Thread-22] frame=  259 fps= 30 q=3.0 size=    1674kB time=00:00:10.28 bitrate=1334.0kbits/s
TRACE 2013-05-22 09:23:36.212 [New I/O worker #2] Resume Read: readCount=586432 / writeCount=1812480
TRACE 2013-05-22 09:23:36.213 [New I/O worker #2] Sent to socket: Accept-Ranges: bytes
TRACE 2013-05-22 09:23:36.213 [New I/O worker #2] Sent to socket: Connection: keep-alive
TRACE 2013-05-22 09:23:36.213 [New I/O worker #2] Sent to socket: Content-Range: bytes 586432-1772223/*
TRACE 2013-05-22 09:23:36.213 [New I/O worker #2] Sent to socket: Content-Type: video/mpeg
TRACE 2013-05-22 09:23:36.213 [New I/O worker #2] Sent to socket: Server: Windows_Server_2008_R2-amd64-6.1, UPnP/1.0, UMS/3.0.0-a1
TRACE 2013-05-22 09:23:36.326 [New I/O worker #2] Calling SetThreadExecutionState ES_CONTINUOUS
TRACE 2013-05-22 09:23:36.327 [New I/O worker #2] Ready to Stop: true
TRACE 2013-05-22 09:23:36.338 [New I/O server boss #5] Creating new pipeline
DEBUG 2013-05-22 09:23:36.367 [Thread-22] frame=  275 fps= 29 q=3.0 size=    1770kB time=00:00:10.92 bitrate=1327.8kbits/s
TRACE 2013-05-22 09:23:36.553 [New I/O worker #3] Opened request handler on socket /10.0.0.7:46433
TRACE 2013-05-22 09:23:36.553 [New I/O worker #3] Calling SetThreadExecutionState ES_SYSTEM_REQUIRED
TRACE 2013-05-22 09:23:36.553 [New I/O worker #3] Request: HTTP/1.1 : GET : get/0$6$39$3$2$3/TV+Noir+mit+Boy+und+Tex+%281%29
TRACE 2013-05-22 09:23:36.553 [New I/O worker #3] Matched media renderer "Android" based on address /10.0.0.7
TRACE 2013-05-22 09:23:36.553 [New I/O worker #3] Received on socket: Connection: close
TRACE 2013-05-22 09:23:36.553 [New I/O worker #3] Received on socket: Host: 10.0.0.2:5001
TRACE 2013-05-22 09:23:36.553 [New I/O worker #3] Received on socket: Icy-MetaData: 1
TRACE 2013-05-22 09:23:36.554 [New I/O worker #3] Received on socket: Range: bytes=40480-
TRACE 2013-05-22 09:23:36.554 [New I/O worker #3] Received on socket: User-Agent: (null)
TRACE 2013-05-22 09:23:36.554 [New I/O worker #3] Recognized media renderer: Android
TRACE 2013-05-22 09:23:36.554 [New I/O worker #3] HTTP: get/0$6$39$3$2$3/TV+Noir+mit+Boy+und+Tex+%281%29 / 40480--1
TRACE 2013-05-22 09:23:36.554 [New I/O worker #3] discover 0 refresh forced: false
TRACE 2013-05-22 09:23:36.554 [New I/O worker #3] discover 0$6 refresh forced: false
TRACE 2013-05-22 09:23:36.554 [New I/O worker #3] discover 0$6$39 refresh forced: false
TRACE 2013-05-22 09:23:36.554 [New I/O worker #3] discover 0$6$39$3 refresh forced: false
TRACE 2013-05-22 09:23:36.554 [New I/O worker #3] discover 0$6$39$3$2 refresh forced: false
TRACE 2013-05-22 09:23:36.554 [New I/O worker #3] cms getinp/2 scrape com.sharkhunter.channel.ChannelMedia@96b86ee url mms://a1014.v1252931.c125293.g.vm.akamaistream.net/7/1014/125293/v0001/wm.od.origin.zdf.de.gl-systemhaus.de/none/zdf/11/09/110909_tvnoir_tvn_vh.wmv
TRACE 2013-05-22 09:23:36.554 [New I/O worker #3] Asked stream chunk : ByteRange [start=40480, end=-1] of TV Noir mit Boy und Tex (1) and player FFmpeg Web Video
TRACE 2013-05-22 09:23:36.554 [New I/O worker #3] Ready to Stop: false
DEBUG 2013-05-22 09:23:36.555 [New I/O worker #3] Setting InputStream new position to: 40,480
TRACE 2013-05-22 09:23:36.555 [New I/O worker #3] Using chunked response. Sending 1812480 bytes.
TRACE 2013-05-22 09:23:36.556 [New I/O worker #3] Sent to socket: Accept-Ranges: bytes
TRACE 2013-05-22 09:23:36.556 [New I/O worker #3] Sent to socket: Connection: keep-alive
TRACE 2013-05-22 09:23:36.556 [New I/O worker #3] Sent to socket: Content-Range: bytes 40480-1852959/*
TRACE 2013-05-22 09:23:36.556 [New I/O worker #3] Sent to socket: Content-Type: video/mpeg
TRACE 2013-05-22 09:23:36.556 [New I/O worker #3] Sent to socket: Server: Windows_Server_2008_R2-amd64-6.1, UPnP/1.0, UMS/3.0.0-a1
DEBUG 2013-05-22 09:23:36.955 [Thread-22] frame=  291 fps= 29 q=3.0 size=    1920kB time=00:00:11.56 bitrate=1360.6kbits/s
TRACE 2013-05-22 09:23:37.174 [Timer-4] buffered: 926,175 bytes / inputs: 1
DEBUG 2013-05-22 09:23:37.625 [Thread-22] frame=  306 fps= 29 q=3.0 size=    2006kB time=00:00:12.16 bitrate=1351.4kbits/s
DEBUG 2013-05-22 09:23:38.235 [Thread-22] frame=  322 fps= 29 q=3.0 size=    2152kB time=00:00:12.80 bitrate=1377.3kbits/s
DEBUG 2013-05-22 09:23:38.845 [Thread-22] frame=  338 fps= 29 q=3.0 size=    2290kB time=00:00:13.44 bitrate=1395.8kbits/s
TRACE 2013-05-22 09:23:39.174 [Timer-4] buffered: 713,183 bytes / inputs: 1
DEBUG 2013-05-22 09:23:39.505 [Thread-22] frame=  353 fps= 28 q=3.0 size=    2408kB time=00:00:14.04 bitrate=1405.0kbits/s
DEBUG 2013-05-22 09:23:40.115 [Thread-22] frame=  369 fps= 28 q=3.0 size=    2474kB time=00:00:14.68 bitrate=1380.6kbits/s
DEBUG 2013-05-22 09:23:40.722 [Thread-22] frame=  385 fps= 28 q=3.0 size=    2592kB time=00:00:15.32 bitrate=1386.0kbits/s
TRACE 2013-05-22 09:23:41.175 [Timer-4] buffered: 848,351 bytes / inputs: 1
DEBUG 2013-05-22 09:23:41.364 [Thread-22] frame=  400 fps= 28 q=3.0 size=    2722kB time=00:00:15.92 bitrate=1400.7kbits/s
DEBUG 2013-05-22 09:23:42.006 [Thread-22] frame=  416 fps= 28 q=3.0 size=    2786kB time=00:00:16.56 bitrate=1378.2kbits/s
DEBUG 2013-05-22 09:23:42.615 [Thread-22] frame=  432 fps= 28 q=3.0 size=    2916kB time=00:00:17.20 bitrate=1388.8kbits/s
TRACE 2013-05-22 09:23:43.174 [Timer-4] buffered: 745,951 bytes / inputs: 1
DEBUG 2013-05-22 09:23:43.219 [Thread-22] frame=  447 fps= 28 q=3.0 size=    3054kB time=00:00:17.80 bitrate=1405.5kbits/s
DEBUG 2013-05-22 09:23:43.879 [Thread-22] frame=  464 fps= 28 q=3.0 size=    3146kB time=00:00:18.48 bitrate=1394.6kbits/s
DEBUG 2013-05-22 09:23:44.485 [Thread-22] frame=  479 fps= 27 q=3.0 size=    3350kB time=00:00:19.08 bitrate=1438.3kbits/s
DEBUG 2013-05-22 09:23:45.098 [Thread-22] frame=  494 fps= 27 q=3.0 size=    3552kB time=00:00:19.68 bitrate=1478.6kbits/s
TRACE 2013-05-22 09:23:45.174 [Timer-4] buffered: 674,271 bytes / inputs: 1
DEBUG 2013-05-22 09:23:45.785 [Thread-22] frame=  510 fps= 27 q=3.0 size=    3806kB time=00:00:20.32 bitrate=1534.4kbits/s
DEBUG 2013-05-22 09:23:46.376 [Thread-22] frame=  526 fps= 27 q=3.0 size=    3904kB time=00:00:20.96 bitrate=1525.8kbits/s
DEBUG 2013-05-22 09:23:46.987 [Thread-22] frame=  541 fps= 27 q=3.0 size=    4114kB time=00:00:21.56 bitrate=1563.2kbits/s
TRACE 2013-05-22 09:23:47.174 [Timer-4] buffered: 1,137,119 bytes / inputs: 1
DEBUG 2013-05-22 09:23:47.642 [Thread-22] frame=  557 fps= 27 q=3.0 size=    4346kB time=00:00:22.20 bitrate=1603.7kbits/s
TRACE 2013-05-22 09:23:47.680 [New I/O worker #3] Ready to Stop: true
DEBUG 2013-05-22 09:23:48.254 [Thread-22] frame=  573 fps= 27 q=3.0 size=    4462kB time=00:00:22.84 bitrate=1600.4kbits/s
DEBUG 2013-05-22 09:23:48.875 [Thread-22] frame=  588 fps= 27 q=3.0 size=    4684kB time=00:00:23.44 bitrate=1637.0kbits/s
TRACE 2013-05-22 09:23:49.174 [Timer-4] buffered: 4,915,200 bytes / inputs: 0
DEBUG 2013-05-22 09:23:49.533 [Thread-22] frame=  602 fps= 27 q=3.0 size=    4910kB time=00:00:24.00 bitrate=1675.9kbits/s
DEBUG 2013-05-22 09:23:50.142 [Thread-22] frame=  620 fps= 27 q=3.0 size=    5010kB time=00:00:24.72 bitrate=1660.3kbits/s
DEBUG 2013-05-22 09:23:50.180 [Buffered IO End Checker] Stopping process: ffmpeg.exe-1
TRACE 2013-05-22 09:23:50.180 [Buffered IO End Checker] Destroying buffer
TRACE 2013-05-22 09:23:50.183 [ffmpeg.exe-1] EOF
INFO  2013-05-22 09:23:51.680 [StopPlaying Event] Stopped playing TV Noir mit Boy und Tex (1) on your Android
DEBUG 2013-05-22 09:23:51.681 [StopPlaying Event] The full filename of which is: mms://a1014.v1252931.c125293.g.vm.akamaistream.net/7/1014/125293/v0001/wm.od.origin.zdf.de.gl-systemhaus.de/none/zdf/11/09/110909_tvnoir_tvn_vh.wmv and the address of the renderer is: 10.0.0.7
DEBUG 2013-05-22 09:23:51.683 [StopPlaying Event] Resume stop. This segment 20358 new time 20358
SharkHunter
TheRc - lets continue in the support thread. And start by uploading the full logs..
TheRec
Post by TheRec »
OK, I have posted here. Thanks for your support.
S7eele
Post by S7eele »
SharkHunter wrote:Here is a new long awaited 2.20 of Channels. It makes use of more url resolvers and resume functionallity plus a whole bunch of misc bugs.
As always SH, thanks for all the work. Looking forward to trying it out, will let you know anything I come upon. Don't guess any of the stuff I reported on the past versions much matters anymore but just reporting things I thought you would want to know. I guess I am a little behind as I was waiting for the UMS Plugin GUI Install menu to refresh the version of channels available. Never saw it move past 2.19.
Anyway, thanks for another upgrade and thanks for a fantastic product!
Peace!
Peace!
SharkHunter
I'm back!!!
New version 2.21 which should sync with latest UMS beta.
Re: Channels Announce (13-10-19
Nice one and welcome back :) I updated the download on the Plugins tab too
