[Solved] UMS is "renaming" the files on the TV
jps92
Re: UMS is "renaming" the files on the TV
Post by jps92 »
I discovered the problem also in the version 4.0.0 only when the "video is resuming" (under linux OS). :cry:
ExSport
Post by ExSport »
Check your renderer.conf for "AccurateDLNAOrgPN = true" if it is not the root cause of problem:
https://github.com/UniversalMediaServer ... issues/494
Raident
Post by Raident »
ExSport wrote:Check your renderer.conf for "AccurateDLNAOrgPN = true" if it is not the root cause of problem:
It's the opposite - setting it to true causes the filename problem.
If the AccurateDLNAOrgPN setting is omitted, the filename problem goes away but in exchange UMS is completely broken and nothing will play.
ExSport
Post by ExSport »
It is not opposite, exactly this way it behaves as it is described in link 8-)
But definitely it is bug.
Please provide logs with problematic file with both settings "AccurateDLNAOrgPN = true + false" to compare it what exactly denies playing the file correctly.
Thx
Sunwind
Post by Sunwind »
ExSport wrote:"AccurateDLNAOrgPN = true"
I changed mine from true to false and it is fixed, and I can still play files normally. This is v5.0.1 with a Sony Bravia EX-503
If someone can confirm the fix it would be great, I'm hoping to include it in the next release ASAP
blami
Post by blami »
SubJunk wrote:If someone can confirm the fix it would be great, I'm hoping to include it in the next release ASAP
Just copied over .jar from .exe you've provided to my linux machine and it seems it fixes the issue on Sony Bravia KDL-40HX750 (movie name is as on harddrive with prettify disabled)
kuran203
Post by kuran203 »
It did fix it for me, on a Bravia ex-700. Thanks
Great, thanks for testing! We will release a new version with the fix soon
