Sony Bravia - Issues & Problems: 2.2.0 vs 2.4.2
Re: Sony Bravia - Issues & Problems: 2.2.0 vs 2.4.2
Wow very strange! Not sure if this will fix it or not, but if it doesn't can you post the trace logs from this one? http://www.spirton.com/uploads/UMS/UMS-Serenus-3.exe
I can't test any video playback cause every folder I open up that has video files on it immediately throws an error "Content could not be acquired" on my TV.
Attached you may find the debug log with Trace enabled.
- ums_dbg_Serenus-3.zip
- (22.79 KiB) Downloaded 870 times
Oh right, yeah that's my fault, here's one that hopefully lets you browse: http://www.spirton.com/uploads/UMS/UMS-Serenus-4.exe
UMS Serenus 4
Anime = NOT OK (doesn't play)
TV Series + Subtitles = NOT OK (doesn't play)
TV Series - Subtitles = OK
Attached you may find the debug log with TRACE on.
- ums_dbg_Serenus-4.zip
- (14.28 KiB) Downloaded 694 times
Thanks for testing, I don't think that's the right debug.log though, according to that log no files were played
Weird, no idea what happened. I just retested and the results are:
Anime = NOT OK (video file cannot be played)
TV Series + Subtitles = OK
As usual the logs are attached.
- ums_dbg_Serenus-4-Verified.zip
- (59.87 KiB) Downloaded 802 times
Cool, thanks. I have a possible fix here: http://www.spirton.com/uploads/UMS/UMS-Serenus-5.exe
There you go, I'm back to not being able to browse through folders cause it crashes on "Content could not be acquired"
- ums_dbg_Serenus-5.zip
- (14.37 KiB) Downloaded 779 times
TRACE 2013-04-29 00:12:27.930 [New I/O worker #1] Network debugger: [DeadFish] Nekomonogatari_ Kuro - Batch [720p][AAC] http-get:*:video/mp4:DLNA.ORG_OP=01 size=674797158 duration=01:39:05.00 http://192.168.2.93:5001/get/0$1$1$5/%5 ... AAC%5D.mp4
TRACE 2013-04-29 00:12:27.930 [New I/O worker #1] Network debugger: http-get:*:video/mp4:DLNA.ORG_OP=01 size=674797158 duration=01:39:05.00 http://192.168.2.93:5001/get/0$1$1$5/%5 ... AAC%5D.mp4
DEBUG 2013-04-29 00:12:27.946 [New I/O worker #1] Caught exception
at net.pms.dlna.DLNAResource.toString(DLNAResource.java:1343) ~[ums.jar:3.0.0]
at net.pms.network.RequestV2.answer(RequestV2.java:691) ~[ums.jar:3.0.0]
at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:295) ~[ums.jar:3.0.0]
at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:253) ~[ums.jar:3.0.0]
at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:142) ~[ums.jar:3.0.0]
at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:148) ~[ums.jar:3.0.0]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:296) ~[ums.jar:3.0.0]
at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:459) ~[ums.jar:3.0.0]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536) ~[ums.jar:3.0.0]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435) ~[ums.jar:3.0.0]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) ~[ums.jar:3.0.0]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) ~[ums.jar:3.0.0]
at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) ~[ums.jar:3.0.0]
at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:107) ~[ums.jar:3.0.0]
at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:312) ~[ums.jar:3.0.0]
at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:88) ~[ums.jar:3.0.0]
at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) ~[ums.jar:3.0.0]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.7.0_15]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.7.0_15]
at java.lang.Thread.run(Unknown Source) [na:1.7.0_15]
Weird exception
After network debugger (in green) you should see the name of file (in red) which is listed on renderer. 1st is ok but 2nd and 3rd is empty and it is weird. It never should be! After that an exception is generated.
It seems there is a null value which is not expected. Don't have source code of this version to say what part of code generated it (hopefully not my network debugger code
2nd and 3rd is same file as first...
Thanks for the test. The exception is expected and proves what I suspected. Today I will work on a proper fix for this
