GitHub attachments
ExSport
Re: GitHub attachments
Post by ExSport »
Visibility debug Build: b7013a6a8 (2015-03-26)
Debug_b7013a6a8.zip
(19.67 KiB) Downloaded 11493 times
infidel
Post by infidel »
For testing this issue. Put the enclosed update.jar next to ums.jar in your UMS program folder, and restart UMS. Remove it after testing.
update-ums-5.1.1-disable-premature-endstop2.zip
for testing ums 5.1.1+ only
(8.32 KiB) Downloaded 12037 times
infidel
Post by infidel »
This is for testing the xbox 360 issue where all items are found in photo folders. Put the enclosed update.jar next to ums.jar in your UMS program folder and restart UMS. Remove it if ineffective (or otherwise at the next UMS release):
update-ums-5.1.2-xbox-id-fix.zip
For UMS 5.1.2 only
(76.24 KiB) Downloaded 12655 times
Roy
Post by Roy »
The fix is working, thanks!
flutteringwisp
Post by flutteringwisp »
(6.57 KiB) Downloaded 12494 times
infidel
Post by infidel »
This is a slightly different patch for the xbox 360 issue where all items are found in photo folders. Put the enclosed update.jar next to ums.jar in your UMS program folder and restart UMS. Remove it if ineffective (or otherwise at the next UMS release):
update-ums-5.1.2-xbox-id-v2.zip
For UMS 5.1.2 only
(76.75 KiB) Downloaded 11972 times
ExSport
Post by ExSport »
Playing MKV with embedded subs ==> file can't be played because subs extraction takes almost 4mins with FFmpeg
(Thumbs OFF to make log more readable)
debug_thumbsOFF_10-47_to_10-50~error_10-51~works.zip
(23.29 KiB) Downloaded 11653 times
Optimus_prime
Post by Optimus_prime »
Samsung Detection Test for Skeptical in relation to Update renderer upnp details commit
link to git commit https://github.com/UniversalMediaServer ... dde1ab6f2f
ums_dbg_SamsungDetectionTest1.zip
(25.78 KiB) Downloaded 11553 times
valib
Post by valib »
(95.66 KiB) Downloaded 11890 times
Optimus_prime
Debug log for FFmpeg Mac versions for new version 5.1.4
Subjunk debug is straight off FFmpeg website and fails to work
ffmpegmac version works fine
debug_subjunk-ffMpeg.log
(338.97 KiB) Downloaded 11668 times
debug_ffmpegmac_version.log
(389.91 KiB) Downloaded 11745 times
