[FIXED] Javaw.exe hangs after UMS quits
squadjot
Re: [SEMIFIXED] Javaw.exe hangs after UMS quits
Post by squadjot »
Problem is 100% gone from all accounts with 2.5.0
Java shuts down right away now.
I've noticed it shuts down faster now too, it used to take about 5 seconds for me but now very fast. Thanks for confirming :)
squadjot
Re: [FIXED] Javaw.exe hangs after UMS quits
Post by squadjot »
Yeah it's great, now i don't have to reinstall my server because of it 8-)
It must have something to do with the change from Java 6 to 7
squadjot
Post by squadjot »
Im sorry to say In 2.5.1 it hangs again
I think a differrence is that if i try to open UMS before javaw instance closes..a new one opens! (being able to play files and all)
just fyi..Ill post logs asap (watching a movie :))
The problem must have never been fixed then because we didn't change anything that would cause that
squadjot
Post by squadjot »
im 100% sure that the problem was gone with 2.5.0! :D
I will have to go back and do the painfull sequence of testing ..older versions.. soforth. =/ joy
Well there weren't many commits between 2.5.0 and 2.5.1 so I can make you some builds to test if you want?
squadjot
Post by squadjot »
Yes, but to save you the trouble, let me first try unsinstall 2.5.1 and install 2.5.0 and let me confirm...
I have installed some windows updates since.. you never know..
I'll get back to you..thanks alot
Cool
