infidel
Re: Jumpy Plugin (24 January 2014)
Post by infidel »
DualC wrote:I trie to install the "net.rieter.xot.repository-1.0.4.zip"
paulinacio1991 wrote:I was wonder if it would be possible to get Trakt.tv to work with UMS?
Jumpy only supports "addons" and these two are "scripts", which are different. Basically nothing in the Programs area of xbmc will run in jumpy.
paulinacio1991 wrote:I know iStream is also incompatible with Jumpy
Some of these "script" plugins can also have fairly intrusive efects on your xbmc installation, e.g. iStream (XUNITY).
DualC
Post by DualC »
Hi.
As far as i know, the plugin can be installed as script or plugin if u read the install page...
But i havent realy understand the diffrence between whem, .. as i think i have tried the both ways and got the same result.
/M
infidel
Post by infidel »
DualC wrote:As far as i know, the plugin can be installed as script or plugin if u read the install page...
Right (assuming we're talking about XOT here), but it looks like the addons depend on the script.
DualC
Post by DualC »
yeah it seems soo. :/ to bad ... it's a good plugin (script) for swedish channels. :/..
yaya, have to look for some other soultion.
infidel
Re: Jumpy Plugin (8 April 2014)
Post by infidel »
Update: jumpy-0.3.2
DualC
Post by DualC »
Hi Infidel...
Nice progress u have made with the new version of jumpy, .. and i also saw u made support for the XOT plugin (script).
, i have tried to install the new Jumpy and also installed XOT, my computer i have UMS on.
But the folders seems emty, .. nothing at all in whem.. both in XBMC and WDTV Live.
I attach some logs for u to look at.
jumpy.log
jumpy log
(53.11 KiB) Downloaded 1097 times
xotPlugin.log
xotPlugin log
(129.53 KiB) Downloaded 1095 times
/M
infidel
Post by infidel »
DualC wrote:and i also saw u made support for the XOT plugin (script).
Entirely accidental, I assure you, but you succeeded in making me feel a bit guilty :). Try this update:
xbmc-dev-140409.zip
Unzip to plugins/jumpy/
(21.28 KiB) Downloaded 1128 times
DualC
Post by DualC »
Hi.. Infidel..
It seems u have mad some progress, .. most of the channels seems to work, ... and the other who's not maybe are down or somthing.
Anyway, .. the channels are showing up well on my WDTV Live, .. but on XBMC i can only see "Clip" .. but no movies.
abre
Post by abre »
Hello. I've got Sony Bravia 40W5500 and UMS + Jumpy + XBMC and I can't get anything from XBMC on my tv, just 'Jumpy' folder (Util, WebReader, Earmarks, Bookmarks and Util) but with no content. The same happens with PS3MS.
ums debug http://pastebin.com/1UtxQRR9
ums.conf http://pastebin.com/pP7zsxDF
jumpy log http://pastebin.com/RfxFuxgg
jumpyscripts.ini http://pastebin.com/SmpSARGG
infidel
Post by infidel »
abre wrote:I can't get anything from XBMC on my tv
jumpy.log wrote:UnicodeDecodeError: 'utf8' codec can't decode byte 0xf3 in position 10
It looks like it's having trouble with the second letter in your Windows username. Try the fix below, and post logs if still no joy:
xbmc-dev-140418.zip
unzip to plugins/jumpy/
(21.68 KiB) Downloaded 1008 times
