Google Music plugin
Re: Google Music plugin
With Google Music Plugin I can make a PC library available to Google Music Player or musics stored at Google Music available to Universal Media Server?
I see a few others getting this error:
gm exceptiuon java.io.FileNotFoundException: https://play.google.com/music/services/loadalltracks
Can anyone suggest what is wrong / how to fix?
Thanks,
Aldur
Thanks,
Aldur
Does the Google Music plugin still work for anyone? Can't even install it.
Thanks!
Thanks!
There's an open pull request against that repo which looks like it might resolve the issues:: https://github.com/SharkHunter/GMPMS/pull/1
I don't have the dev and build envs setup to try it though.
I'd like to try to get the Gmusic plugin working... I have a Play Music subscription.
This is the link for where I can see my playlists: https://play.google.com/music/listen#/wmp
There are a few errors for URLs: "gm exceptiuon java.io.FileNotFoundException: https://www.google.com/accounts/ClientLogin" and "gm exceptiuon java.io.FileNotFoundException: https://play.google.com/music/services/ ... st?u=0&xt="
I'm not sure where the playlist URL is defined in the plugin. I was able to follow the instructions for building my own plugin, but got stuck along the way gradle.
