Sony Bravia - Issues & Problems: 2.2.0 vs 2.4.2
Serenus
Re: Sony Bravia - Issues & Problems: 2.2.0 vs 2.4.2
Post by Serenus »
Here's another one with Trace Enabled.
cut off playing: Hannibal.S01E06.HDTV.x264-2HD
it missed like 15 seconds
ums_dbg-2.6.3_TRACE_ENABLED.zip
(135.9 KiB) Downloaded 735 times
AFAIK that has been an issue ever since PMS started to use tsMuxeR (since 2010). If you disable the "remux with tsmuxer" MEncoder option it shouldn't happen.
I've never noticed it happening myself but then most of my videos have credits after them which I don't watch
Can you try this new version and let me know how it works for you with regards to the file support (anime, subtitles, etc.)? http://www.spirton.com/uploads/UMS/UMS-Serenus-8.exe
Serenus
Post by Serenus »
I've just downloaded and installed the latest build and will let you know how it works by the end of the day.
Would it help you if I found a build that didn't cut off the last 15 seconds? I think I got archived pretty much every build from PMS Subjunk up till now on my NAS and I'm sure quite a few didn't cut off the last 15 seconds.
/fanboy t-shirt
Serenus
Post by Serenus »
Here' s the test results:
TV Show - Subtitle = I get the sound but I don't get any Video/Subtitle
TV Show + Subtitle = OK
Anime = 3 out of 4 files didn't work
  • [HorribleSubs] One Piece - 593 [360p] = OK
  • [HorribleSubs] Naruto Shippuuden - 310 [1080p] = Didn't play at all, "Video content cannot be played"
  • [DeadFish] Nekomonogatari_ Kuro - Batch [720p][AAC] = I only got sound but no Video/Subtitle
  • [UTW-Mazui]_Nekomonogatari_Black_[720p][4C075E10] = Didn't play at all, "Video content cannot be played"
Here's the debug log with TRACE on and all mediainfo files for the Anime videos.
MediaInfoAnime.7z
(3 KiB) Downloaded 735 times
ums_dbg_Serenus-8.zip
(86.89 KiB) Downloaded 875 times
OK hopefully this one will give the same results we had with the almost-perfect one, can you confirm? http://www.spirton.com/uploads/UMS/UMS-Serenus-9.exe
Serenus
Post by Serenus »
Here' s the test results (this is by far the best build for Anime files):
TV Show - Subtitle = It doesnt play at all.
Anime = 3 out of 4 files Worked!
[HorribleSubs] Naruto Shippuuden - 310 [1080p] = OK
[DeadFish] Nekomonogatari_ Kuro - Batch [720p][AAC] = NOT OK
[UTW-Mazui]_Nekomonogatari_Black_[720p][4C075E10] = OK
Here's the debug log with TRACE ENABLED. I can tell that browsing through the folders got slower than the usual tho, it takes longer to load the list.
ums_dbg_Serenus-9.zip
(111.93 KiB) Downloaded 616 times
OK, great. This one should hopefully fix the first case, does it? http://www.spirton.com/uploads/UMS/UMS-Serenus-10.exe
Serenus
Post by Serenus »
WOW! This is badass! It's playing EVERYTHING I throw at it!
All previously tested Anime files worked, TV + Subtitles and TV - Subtitles! Plus navigating doesn't feel sluggish anymore.
I'm attaching the debug log with TRACE ENABLED.
I'll keep testing today and tomorrow and let you know.
ums_dbg_Serenus-10.zip
(89.63 KiB) Downloaded 699 times
Great, I was hoping for that, thanks for the testing!
