[Testers Required] UMS Running on Java 7
Optimus_prime
Re: [Testers Required] UMS Running on Java 7
Post by Optimus_prime »
Ok Cyberbooster, there's one there called UMS 3.0.0-b1-Java7.dmg i rebuilt for you. give that a go please
cyberbooster
Post by cyberbooster »
With Safari, same issue.
I'm trying with firefox now. I'll update the post once the download is finished.
EDIT: nope. same issue. But Finder tells me last modification date 22 Oct 11:29
Optimus_prime
Thats strange behavior as i built it moments before i posted on here. Not sure what the issue is mate, any ideas
cyberbooster
I really don't know.
I'll try later or tomorrow to start it up from Terminal and look if it tells me something. I'll update as soon as possible
cyberbooster
Ok, I managed to start the server using Terminal.
You can check the log here: http://pastie.org/8443718 (i renamed my username with <UserName>)
Any idea?
EDIT: subtitles don't work :(
Optimus_prime
i can't see anything in your log, but i'm not sure what i'm looking for. There's no java exceptions or anything. Sorry mate, theres just nothing there, and it's got me puzzled to why it's having issues. Ill continue to see if i can see anything, hopefully someone else post with similar issues so i can narrow down the issues and fix it (or tell you how)
cyberbooster
Ok, maybe I found the issue, I'll check later.
This maybe has to do with GateKeeper security (so I have to check if bypassing it will work), since I enforced a total lockdown on apps (my mac is used also by other non-techie person).
The error is misleading, since it tells me that it's corrupted, when it's not.
Optimus_prime
Everyone running UMS OS-X Java 7 version there's a new version up for 3.0.0
Please check and see if subtitles are working correctly
cyberbooster
Ok, with Beta version I tested earlier, the issue is resolved by manually disabling Gatekeeper function from preference pane and then running it. Ctrl+click -> open WILL NOT BE ENOUGH.
I'll try 3.0.0 later this day.
EDIT:
Ok, it works, but ONLY IF GATEKEEPER IS DISABLED FOR THE FIRST RUN. After the first run you can enforce the lockdown as usual.
cyberbooster
Subtitles won't work with WD TV Live Streaming.
My srt has the same name as mkv in the same folder.
This is my config (I'm not English native, but I like original language subtitles).
