Problem with ums-6.7.0
boss
Re: Problem with ums-6.7.0
Post by boss »
I have tested my image folders with the latest "update.jar" file and the error is no longer happening.
One other thing I will mention that I also discovered but is also now fixed.
If the number of Images and sub folders was also dividable by 10 the "network error" was happening.
EG: 149 Images in a folder and 1 sub folder would give the error. Remove the sub folder and no error.
So, as far as I can see now everything is working fine with Images and my 2 x LG-BP550 players.
Would the changes you made in the "update.jar" file be implemented in future ums versions or would that cause some issues in other renderers?
Thank you for your ongoing support which is appreciated.
None of the fixes I've made now should cause any trouble as far as I can see, so it is my intention to merge them so that they will be in the next release.
Thank you for reporting back.
