infidel
Re: Jumpy Plugin (5 March 2015 - Kodi update)
Post by infidel »
@nickhere, Out of time for now, the 'd' version *should* fix endgadget (works for me). On genesis it's only a partial fix apparently. I tried some TV shows, e.g. 'parks & rec', which were working (depending on the source, of course) but on 'avatar' I got the same results as you. I haven't looked at apple podcasts, fox news, etc.
nickhere
Post by nickhere »
I did a quick test on engadget wont stream for me to tv or phone
problem must be my end i will look deeper tomorrow
nickhere
Post by nickhere »
ok i got tired of nothing working with the panasonic for me so i tried jumpy crackler and bubble upnp barney miller IT WORK
so i went back to my tv and did the same via wire and wireless IT doesn't work
Here are the logs.
try to load then get cant read file
(592.8 KiB) Downloaded 774 times
nickhere
Post by nickhere »
it look like the stream is sending but not responding on tv.
crackler ended up working only if it had the transcoder folder and used mencoder
infidel
Re: Jumpy Plugin (6 March 2015 - Kodi update)
Post by infidel »
nickhere wrote:I did a quick test on engadget wont stream for me
Version 'e' is up, with yet another bugfix :) .
Also I had been in Linux yesterday but tested in Windows today and got endgadget+genesis+itunespodcasts+foxnews+crackler all working after some manual repairs to the Kodi addons folder, which had to do with missing dependencies caused by an incomplete manual install of the gotham version of urlresolver and some other addons.
Here's the basic repair procedure for anyone experiencing similar issues:
Part 1: Repair urlresolver:
  • Install the youtube addon in Kodi.
  • Open up your Kodi addons folder (located at %APPDATA%\Kodi\addons).
  • Install (or re-install) these addons (download latest from the gotham addons page and unzip to your Kodi addons folder):
    • script.module.urlresolver
    • script.common.plugin.cache
    • script.module.parsedom
    • script.module.simple.downloader
    • script.module.t0mm0.common
    • script.module.simplejson
  • Restart ums.
Part 2: Repair any other missing gotham addons similarly, if you see lines like these in your jumpy.log's jumpy-xbmc load section (using @nickhere's log as an example):
jumpy-xbmc version 0.3.11c
Error: script.globalsearch not found.
Error: plugin.video.ustvnow not found.
Error: script.tv.show.next.aired not found.
Error: script.artwork.downloader not found.
Error: plugin.video.vimeo not found.
Error: script.extendedinfo not found.
Error: plugin.program.super.favourites not found.
Error: script.module.pysqlite not found.
Error: script.module.sqlite not found.
Notes:
  • Some of these may need to be downloaded from the addon's home site.
  • You can also copy these addons from your %APPDATA%\XBMC\addons folder if existing, though these may not be the latest versions.
  • It may take several iterations to complete the repair, as the new addons may have missing sub-dependencies.
nickhere
Post by nickhere »
what the easiest way to copy those to my kodi directory
i have ton of addon repo
and some of those addon on the site are not zip
nickhere
Post by nickhere »
OK i video record what happening on my tv screen and what happening in ums
it in the log files
get it from my onedrive
it to big to upload video here
http://1drv.ms/1GsdETe
i only did apple podcast
infidel
Post by infidel »
nickhere wrote:OK i video record what happening on my tv screen and what happening in ums
Thx, but it's not necessary to send videos, your logs show the errors well enough :). I'm mostly concerned here with whether jumpy is delivering the media links correctly to ums. If you have transcoding problems with specific renderers, that's a separate issue.
nickhere
Post by nickhere »
infidel wrote:[that's a separate issue.
I know the render is a seperate issue.
What do you want me to check and log.
for the most part i think jumpy delivers
nickhere
Post by nickhere »
I been looking at jumpy code. YOU really did a lot of work. Well appreciated. Since there are so many addons for kodi i may endup trying to enhance it. Like adding auto downloading from the repository and installing the add on + add on checking to see if the base site is ok. On a side note i recently purchase a pogoplug pro http://www.adorama.com/COCPOGOP02.html it has some type of linux built in. It might be possible to run UMS on certain models of it. With that and a jumpy interface i would not need to install kodi
