UMS 10.6-10.8.2 Stuttering videos
Startropic1
Re: UMS 10.6-10.8.2 Stuttering videos
Post by Startropic1 »
SubJunk wrote: Fri Aug 27, 2021 4:53 pm Can you please re-enable those settings and try this build too? https://www.universalmediaserver.com/up ... 9998e0.exe
We need to be careful how many variables we put into play.
I have added a new zip of logs to https://mega.nz/folder/KjAixRoT#U6KBcSOCFQNVGsr4DIMB0g
and now I'm going to install build 538d288
I will re-enable the cache settings when I install 69998e0 later. (I can possibly do this test with 538d288 as well, but we have to at least test it without re-enabling first.)
Your latest log is 15meg which is a good sign and you should be able to post your logs directly on the forum.
Since the is no longer the amount of spam from your TV it suggests that it was a problem with the cache in UMS, or how it handles the search requests.
The latest build should have a fix for what we think was the cause of the problem so it's probably better to just try that straight away with the cache enabled to confirm.
I think the change has been added to version 10.10.1 if you want to try that after
Changes since 10.10.0:
General:
Up to 4x browsing speed improvement (thanks, ik666!)
Disabled UPnP search while we fix problems with it
Fixed sending MusicBrainz info for non-audio files
Fixed the older HTTP engine
If that works then we can figure out if that was having a negative effect on network speed for your PS4 issues
Startropic1
latest log small enough to attach. It's off of build build 538d288 and I'm having some playback issues today. I will go ahead and update to newer build.
ums_dbg_2021-09-08-11-47.zip
(1.55 MiB) Downloaded 330 times
When you do make sure to re-enable the cache as that may have been causing the original problem and would be good to see if has been fixed.
Startropic1 wrote: Thu Sep 09, 2021 3:51 am latest log small enough to attach. It's off of build build 538d288 and I'm having some playback issues today. I will go ahead and update to newer build.
We also need to know what the playback issues are, specifically
Did you ever get a chance to run https://www.universalmediaserver.com/up ... 9998e0.exe ? That is a simple fix that may be all that is needed
