Re: Jumpy Plugin (27 August 2015)
Coolinfidel wrote: It should be working now in jumpy-0.3.9 (there was an additional issue with setting multiple cookies for ffmpeg, fixed now).
- Supermanfan77
Re: Jumpy Plugin (21 February 2016)
I wonder if that will fix the issue I've had with the audio on certain sites? How do I add this fix to the current version of jumpy?infidel wrote:I'm guessing it has to do with the query string after '.m3u8' in the url:kuroukage wrote:What's wrong with the FFMPEG binary in the current build? It just wasn't compiled properly?which triggered a bug in ffmpeg m3u/hls support for builds between Jan 16-31, see the fix here.http://video14.lax01.hls.ttvnw.net/hls- ... -live.m3u8?token=id=2492499106749648834...
This doesn't involve jumpy, but rather updating the ums 6.0+ ffmpeg binary. It only applies if your issue first appeared in ums 6+ and only if the files/urls involved are m3u/m3u8.Supermanfan77 wrote:I wonder if that will fix the issue I've had with the audio on certain sites? How do I add this fix to the current version of jumpy?
Hey Infidel,
I'm having another issue. After I play a stream on TwitchTV with Jumpy for awhile and then I exit it and try to play another stream it gives me a "network error 0000001F4." I've tried doing a refresh with Jumpy and also turning the PS3 off and on and the only way I can seem to fix it is if I exit and reload UMS from my PC. If I try to reload UMS from my PS3 I end up having to reboot my PC. Any idea what could be wrong?
This is from the Jumpy .log file:
Also, this is the latest build of Kodi (and addons): ver. 16.
run_addon: plugin://plugin.video.twitch/playLive/nycfurby/
Settings: {u'username': '####', u'titledisplay': u'4', u'video': u'1', u'titletruncate': u'true'}
loading plugin.video.twitch
importing __main__.converter as converter
importing __main__.xbmcswift2 as xbmcswift2
Error: run_addon
Traceback (most recent call last):
File "C:\Program Files (x86)\Universal Media Server\plugins\jumpy\xbmc\xbmcinit.py", line 521, in run_addon
exec codeobj in mod.__dict__
File "C:\Users\Madara\AppData\Roaming\KODI\addons\plugin.video.twitch\default.py", line 39, in <module>
@PLUGIN.route('/')
File "C:\Users\Madara\AppData\Roaming\KODI\addons\script.module.xbmcswift2\lib\xbmcswift2\plugin.py", line 246, in decorator
self.add_url_rule(url_rule, f, name=view_name, options=options)
File "C:\Users\Madara\AppData\Roaming\KODI\addons\script.module.xbmcswift2\lib\xbmcswift2\plugin.py", line 266, in add_url_rule
'"%s"', url_rule, name, view_func.__name__)
File "c:\Python27\lib\logging\__init__.py", line 1148, in debug
self._log(DEBUG, msg, args, **kwargs)
File "c:\Python27\lib\logging\__init__.py", line 1279, in _log
self.handle(record)
File "c:\Python27\lib\logging\__init__.py", line 1288, in handle
if (not self.disabled) and self.filter(record):
File "c:\Python27\lib\logging\__init__.py", line 615, in filter
if not f.filter(record):
File "C:\Users\Madara\AppData\Roaming\KODI\addons\script.module.xbmcswift2\lib\xbmcswift2\logger.py", line 68, in filter
xbmc_level = XBMCFilter.xbmc_levels.get(
AttributeError: 'NoneType' object has no attribute 'xbmc_levels'
[jumpy] latest version is 0.3.9
天 黒影 天
I've seen this before, but haven't yet chased down the bug (it generally has to do with how jumpy re-uses loaded python modules as opposed to reloading them every time, which saves time). Will look at it again, but meanwhile you can work around it:kuroukage wrote:Code: Select all
- Disable "resolve at playback" for the addon, i.e.in the gui open Jumpy > Scripts > jumpy-xbmc and add to the force_resolve box:then save and restart ums.
plugin.video.twitch
Thanks for the quick fix for now.infidel wrote:I've seen this before, but haven't yet chased down the bug (it generally has to do with how jumpy re-uses loaded python modules as opposed to reloading them every time, which saves time). Will look at it again, but meanwhile you can work around it:
How often does this happen with Kodi addons? I haven't tried a ton with Jumpy as of late. I've only have been using it mainly for Twitch. Are you going to have to write a new version to fix this problem?
天 黒影 天
I may have jumped the gun with that "all". Now my local web streams stopped working. It was ok with 0.3.7 version though.Larus wrote:Coolinfidel wrote: It should be working now in jumpy-0.3.9 (there was an additional issue with setting multiple cookies for ffmpeg, fixed now).
All flawless now, thanks!
I mean such streams:
videostream.Web,TV=ACE-VLC,http://127.0.0.1:8903
videostream.Web,TV=SOP,http://127.0.0.1:8902/tv.ts
Do you have an idea what's changed in newest version that could have broken those streams ?
Re: Jumpy Plugin (26 February 2016)
oops, an unintended regressionLarus wrote:Now my local web streams stopped working. It was ok with 0.3.7 version though.
That was quick
Looks fixed, thanks.
Should be fixed nowkuroukage wrote:Code: Select all
