[Testers Required] UMS Running on Java 7
- Optimus_prime
Re: [Testers Required] UMS Running on Java 7
Thanks for testing so far cyberbooster, i'm sorry but i'm trying to check the issue and catch up on my work. Work's winning atm, but i'll have a look shortly
- Optimus_prime
New build up for you guys to test for me, let me know if there are any issues.
Thanks for your efforts mate!
I'll give it a go today and report As soon as possible.
Nope, still nothing.
I tried to modify the wdtv profile with some suggestion received from the forum (don't recall the exact parameter, but was something like stream file information = mkv) but i ended with an empty library, so I reverted back.
No luck yet.
No luck yet.
- Optimus_prime
So the Java 7 version is delayed for a few days due to an issue on my end. Still have no idea as to your issue cyberbooster, i'll keep looking
cyberbooster wrote:Nope, still nothing.
No luck yet.
StreamExtensions= MKV
TranscodeExtensions= MKV
MediaInfo = True
Universal Media Server Wiki!
- Optimus_prime
Java 7 3.3.0 is up on Sourceforge
the CPU fan died :/ I had to buy a replacement, I wil not be able to test the new version before friday, I will report shortly after. Should I change the default profile for the WD TV?
- Optimus_prime
Why not try it. Just copy the original and put it somewhere for safe keeping then modify the original. See if anything changes.
Ok. New Heatsink (Cooler Master Hyper 512 EVO, awesome!)
I tried with 3.3.0 and:
No luck.
BTW, is there any mode to enable GPU acceleration on osx?
# Profile for WD TV Live.
RendererName=WD TV Live
# WDHD Live
# User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 Intel MicroStack/1.0.1423
UserAgentSearch=alphanetworks|INTEL_NMPR/2.1 DLNADOC/1.50 Intel MicroStack/1.0.1423
Video=true
Audio=true
Image=true
SeekByTime=false
TranscodeVideo=MPEGPSAC3
TranscodeAudio=WAV
DefaultVBVBufSize=false
MuxH264ToMpegTS=false
MuxDTSToMpeg=true
WrapDTSIntoPCM=false
MuxLPCMToMpeg=false
MaxVideoBitrateMbps=0
MaxVideoWidth=0
MaxVideoHeight=0
MediaInfo = false
TranscodeExtensions =
StreamExtensions =
# Supported video formats:
Supported = f:mpegps|mpegts m:video/mpeg
Supported = f:avi|divx m:video/x-divx
Supported = f:mp4 m:video/mp4
Supported = f:wmv m:video/x-ms-wmv
# Supported audio formats:
Supported = f:wav m:audio/wav
Supported = f:mp3 m:audio/mpeg
Supported = f:aac m:audio/x-m4a
Supported = f:wma m:audio/x-ms-wma
Supported = f:flac m:audio/flac
Supported = f:mka m:audio/x-matroska
Supported = f:ogg m:audio/ogg
# Supported image formats:
Supported = f:jpg m:image/jpeg
Supported = f:png m:image/png
Supported = f:gif m:image/gif
Supported = f:tiff m:image/tiff
# Show the duration of a DVD Title in the overview
ShowDVDTitleDuration=true
# CBR bitrate. Needed for byteseek to timeseek convertion. 0 = disabled.
CBRVideoBitrate=15000
# Number of seconds to rewind every time we do a byteseek to timeseek conversion.
# If the conversion isn't 100% accurate so a little rewind can be nice
ByteToTimeseekRewindSeconds=0
SupportedSubtitlesType = SUBRIP
