Help us improve support for your devices
Re: Help us improve support for your devices
Hi. I have been using mediaserver for years and first time im in trouble...
I just bought new samsung UE65JU7005 and it does not show subtitles... =(
My older Samsung UE55D8005 works and Panasonic 65VT60 works 90%
Sorry but you have to try to repeat the bug before you send the debug.log. Please try to play on your TV movie with subtitles to be seen in the log what is the TV asking for.
Sorry. Here is New one
- (554.79 KiB) Downloaded 782 times
I have found something strange in your log. Can you try to play your testing file again but on your Samsung UE55D8005 and post the log to see the difference?
OH. You mean SAMMY UE65JU7005 .. Because that 55 Sammy is not currently online.
Is the strange thing because i also went to transcode folder and tried to start ffmpeg, tsmuxer, no transcode... all from there also and no text..
But here is new debug.
- (1.1 MiB) Downloaded 697 times
If you want you can try the latest build you can find at the address http://universalmediaserver-ci.hopto.or ... t.pms$ums/
Ok.I tired clean install on 5.15. No help there. TV is recongnized as E+ series?
I went also trhu transcode folder to try all options and FFmpeg with SUB worked but also lost ability to Rewind.. and pic is horrible.. =)
Can you try again to play your testing file with the UMS version 5.15 and send the log? And please for the troubleshooting purpose let only samsung UE65JU7005 to be connected on the net and the rest of your devices switch off or disconnect. It is horrible to read almost 120 000 lines of the log. Try to stream one video with external subs to see how the samsung UE65JU7005 correspond. There was a bug in the UMS and I want to see if something changed. And the last remark. Be sure that you have set on Closed Captions on your TV to be shown (or Subtitles. I have no idea how Samsung has implemented it).
Just got a Sony KD-55X8505C, one of the new 2015 Android TV.
Can't get any video files to play, even when I tryed to make a new profile based on XboxOne or PS4.
- Sony KD-55X8505C log files
- (27.01 KiB) Downloaded 664 times
It seems to me that you didn't follow instruction in the FAQ http://www.universalmediaserver.com/faq ... erSupport1 because your TV is not properly recognized. First of all you need to make UMS to recognize your TV so I recommend to follow instructions and use
EDIT: I also recommend to use e.g. Sony-BraviaHX.conf as a basic for testing with changes of code written above. The TV is based on Android but it is marked as Bravia so I expect that it could work similarly.
UserAgentAdditionalHeader = X-AV-Client-Info
UserAgentAdditionalHeaderSearch = BRAVIA KD-55X8505C
