Iptables with media server
The media server worked perfectly untill I have rewrited my iptables rules. I have opened tcp, udp ports for 5001 and UPNP service.
Here are the rules:
and here is the log for the server startup:
For some reason, it seems that the rules are blocking the server from working. Can somebody please help me ?
Thank you very much !
Here are the rules:
Chain INPUT (policy DROP 0 packets, 0 bytes)
pkts bytes target prot opt in out source destination
174 33160 ACCEPT all -- lo * 0.0.0.0/0 0.0.0.0/0
14333 4180K ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
320 114K LOGNDROP all -- * * 0.0.0.0/0 0.0.0.0/0
Chain FORWARD (policy DROP 0 packets, 0 bytes)
Chain OUTPUT (policy DROP 660 packets, 48987 bytes)
350 41784 ACCEPT all -- * lo 0.0.0.0/0 0.0.0.0/0
14345 5597K ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
0 0 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:25
0 0 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:53
52 3120 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:80
0 0 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:110
14 840 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:443
10 600 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:51413
0 0 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:6969
1 328 ACCEPT udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpts:67:68
101 6596 ACCEPT udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:53
4 366 ACCEPT udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:51413
0 0 ACCEPT udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:5001
0 0 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:5001
0 0 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:2869
111 28986 ACCEPT udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:1900
Chain LOGNDROP (1 references)
320 114K LOG all -- * * 0.0.0.0/0 0.0.0.0/0 LOG flags 0 level 4
320 114K DROP all -- * * 0.0.0.0/0 0.0.0.0/0
06-16 13:00:29 Starting Universal Media Server 2.6.5
06-16 13:00:29 Based on PS3 Media Server by shagrath, copyright 2008-2013
06-16 13:00:29 http://www.universalmediaserver.com
06-16 13:00:29
06-16 13:00:29 Build: 54bd7b6d1 (2013-06-06)
06-16 13:00:29 Java: 1.7.0_21-Oracle Corporation
06-16 13:00:29 OS: Linux 64-bit 3.5.0-34-generic
06-16 13:00:29 Encoding: UTF-8
06-16 13:00:29 Memory: 682 MB
06-16 13:00:29
06-16 13:00:29 Working directory: /:)/:)/Desktop/ums-2.6.5
06-16 13:00:29 Temp directory: /tmp/universalmediaserver
06-16 13:00:29 Logging config file: /:)/:)/Desktop/ums-2.6.5/logback.xml
06-16 13:00:29 debug.log: /:)/:)/Desktop/ums-2.6.5/debug.log
06-16 13:00:29
06-16 13:00:29 Profile directory: /root/.config/UMS
06-16 13:00:29 Profile path: /root/.config/UMS/UMS.conf
06-16 13:00:29 Profile permissions: rw
06-16 13:00:29 Profile name: intersys
06-16 13:00:29
06-16 13:00:29 Error loading libzen: Unable to load library 'zen': libzen.so: cannot open shared object file: No such file or directory
06-16 13:00:29 Loading MediaInfo library
06-16 13:00:29 Error loading MediaInfo library: Unable to load library 'mediainfo': libmediainfo.so: cannot open shared object file: No such file or directory
06-16 13:00:29 Make sure you have libmediainfo and libzen installed
06-16 13:00:29 The server will now use the less accurate FFmpeg parsing method
06-16 13:00:29 Loading renderer configurations from /:)/:)/Desktop/ums-2.6.5/renderers
06-16 13:00:29 Loading configuration file: VizioSmartTV.conf
06-16 13:00:29 Loading configuration file: Showtime3.conf
06-16 13:00:29 Loading configuration file: XBOX360.conf
06-16 13:00:29 Loading configuration file: FreeboxHD.conf
06-16 13:00:29 Loading configuration file: WDTVLive.conf
06-16 13:00:29 Loading configuration file: Bravia4500.conf
06-16 13:00:29 Loading configuration file: iPad-iPhone.conf
06-16 13:00:29 Loading configuration file: OPPOBDP83.conf
06-16 13:00:29 Loading configuration file: SonyBluray.conf
06-16 13:00:29 Loading configuration file: BraviaHX.conf
06-16 13:00:29 Loading configuration file: Philips.conf
06-16 13:00:29 Loading configuration file: Android.conf
06-16 13:00:29 Loading configuration file: NetgearNeoTV.conf
06-16 13:00:29 Loading configuration file: AirPlayer.conf
06-16 13:00:29 Loading configuration file: PopcornHour.conf
06-16 13:00:29 Loading configuration file: SamsungAllShare.conf
06-16 13:00:29 Loading configuration file: DLinkDSM510.conf
06-16 13:00:29 Loading configuration file: OnkyoTX-NR717.conf
06-16 13:00:29 Loading configuration file: Realtek.conf
06-16 13:00:29 Loading configuration file: SMP-N100.conf
06-16 13:00:29 Loading configuration file: WMP.conf
06-16 13:00:29 Loading configuration file: YamahaRXA1010.conf
06-16 13:00:29 Loading configuration file: BraviaEX620.conf
06-16 13:00:29 Loading configuration file: BlackBerryPlayBook-KalemSoftMP.conf
06-16 13:00:29 Loading configuration file: Showtime4.conf
06-16 13:00:29 Loading configuration file: TelstraTbox.conf
06-16 13:00:29 Loading configuration file: OPPOBDP93.conf
06-16 13:00:29 Loading configuration file: DirecTVHR.conf
06-16 13:00:29 Loading configuration file: SharpAquos.conf
06-16 13:00:29 Loading configuration file: PS3.conf
06-16 13:00:29 Loading configuration file: VideoWebTV.conf
06-16 13:00:29 Loading configuration file: YamahaRXV3900.conf
06-16 13:00:29 Loading configuration file: PhilipsPFL.conf
06-16 13:00:29 Loading configuration file: XBMC.conf
06-16 13:00:29 Loading configuration file: SamsungWiseLink.conf
06-16 13:00:29 Loading configuration file: SonyHomeTheatreSystem.conf
06-16 13:00:29 Loading configuration file: Streamium.conf
06-16 13:00:29 Loading configuration file: Panasonic.conf
06-16 13:00:29 Loading configuration file: Samsung-SMT-G7400.conf
06-16 13:00:29 Loading configuration file: Bravia5500.conf
06-16 13:00:29 Loading configuration file: Kuro.conf
06-16 13:00:29 Loading configuration file: BraviaEX.conf
06-16 13:00:29 Loading configuration file: YamahaRXV671.conf
06-16 13:00:29 Loading configuration file: N900.conf
06-16 13:00:29 Loading configuration file: LGST600.conf
06-16 13:00:29 Loading configuration file: FreecomMusicPal.conf
06-16 13:00:29 Please wait while we check the MPlayer font cache, this can take a minute or so.
06-16 13:00:29 Finished checking the MPlayer font cache.
06-16 13:00:29 Searching for plugins in /:)/:)/Desktop/ums-2.6.5/plugins
06-16 13:00:29 Found plugin: net.pms.movieinfo.MovieInfo
06-16 13:00:29 Registering transcoding engine: FFmpeg Audio
06-16 13:00:29 Registering transcoding engine: MEncoder
06-16 13:00:29 Registering transcoding engine: MPlayer Audio
06-16 13:00:30 Registering transcoding engine: FFmpeg Web Video
06-16 13:00:30 Registering transcoding engine: MEncoder Web
06-16 13:00:30 Registering transcoding engine: MPlayer Video Dump
06-16 13:00:30 Registering transcoding engine: MPlayer Web
06-16 13:00:30 Registering transcoding engine: tsMuxeR
06-16 13:00:30 Registering transcoding engine: Audio High Fidelity
06-16 13:00:30 Registering transcoding engine: VLC Audio Streaming
06-16 13:00:30 Registering transcoding engine: VLC Video Streaming
06-16 13:00:30 Registering transcoding engine: dcraw Thumbnailer
06-16 13:00:30 Using address /10.100.102.3 found on network interface: name:eth0 (eth0)
06-16 13:00:30 Created socket: /10.100.102.3:5001
06-16 13:00:30 Using the following UUID configured in UMS.conf: 9a95d152-20a5-4f93-88c1-1ac10367aa6c
06-16 13:00:30 The server is now available for renderers to find
Re: Iptables with media server
IIRC discovery also need UDP:1900 port as well.
I am sorry but I didn't understand you. What do you mean ? I have opened udp port 1900.Wolfgan wrote:IIRC discovery also need UDP:1900 port as well.
I have also added port 5001 in the input chain and it seems that the problem was solved.
Thank you.
Thank you.
