Panasonic ffwd rwd
Panasonic ffwd rwd
Thanks Subjunk for your release of UMS.
One problem remains which I have never been able to resolve. Rendering to a Viera Plasma G20 when streaming avi, ts or mpeg files ffwd & rwd is either unresponsive or crashes mencoder and java leaving a huge memory leak.
This has been present on PMS for yonks and the last working version I have is Sharkhunter PMS Build SHB24 using PMS 1.40.0.
Any clues / ideas what needs to be done?
Ta.
Ta.
Re: Panasonic ffwd rwd
Hi toontoon, maybe SharkHunter can help since his build is the one that worked. I'll let him know about this thread
- SharkHunter
- Developer
Somewhere after SHB27 (I think) PMS rewrote the whoule buffering scheme. I then found out that my BRAVIA wasn't found of how bffers growed etc. In UMS there is a conf option called "buffer_max" set this to true to make UMS grow the buffer to it's max size at start of transcoding. Otherwise upload some logs..
Prefably a SHB24 log set and then a UMS log set
Thanks Sharkhunter. Will do so you can see the differences.
Just thinking about this (because it is driving me
) is UMS transcoding where PMS was not. For example any avi file on later SHB builds and now UMS begins after a "please wait" message (Viera message) whereas on the old SHB24 build a percentage bar appears and the file plays once 100% reached.
Will also play about with the buffer setting and report back.
Hi Sharkhunter,
On UMS I set buffer_max = true which when failed (see attached debug.log). It actually crashed mencoder and UMS once trying to ffwd through the stream.
Will send a debug.log of the same file successfully seeking ffwd next post.
debug.log
- (47.9 KiB) Downloaded 649 times
Here is another example of UMS debug.log when trying to seek ffwd during an avi. This is without buffer_max set but with force framerate parsed from FFmpeg set to true.
Still failed and crashed.
debug.log
- (55.85 KiB) Downloaded 593 times
For whatever reason I can't set the debug level correctly - therefore pointless uploading a debug.log which doesn't shed any light on why this works in earlier versions.
How can I get the same level of debug in the working SHB build?
- SharkHunter
- Developer
Find this section (in the logback.xml)
and add (if missing)
To make sure uppdate the also.
This should be the same on UMS/PMS/PMS_SHB
<appender name="debug.log" class="ch.qos.logback.core.FileAppender">
<filter class="ch.qos.logback.classic.filter.ThresholdFilter">
<level>ALL</level>
</filter>
<root level="ALL">
Hi Sharkhunter,
logback.xml attached as it appears to be setup correctly.
logback.xml
- (3.21 KiB) Downloaded 696 times
Finally been able to post a debug.log with correct ffwd and rwd on an avi file as discussed.
Any ideas how this can get fixed in the later versions.
debug.log
- (234.12 KiB) Downloaded 718 times
