UMS won't play 4k video.
I have an SAMSUNG UE43KU6072 and i have latest UMS version installed. When i'm trying to play 4k straight from pc with UMS i get an error on my Samsung that the file can't be played. When i copy on a USB stick the movie, works perfectly.
I attachet the log files like in the tutorial, and i'm hoping you can help me.
Note that only 4k are with problem, the 1080p movies works perfectly.
- (129.18 KiB) Downloaded 443 times
Re: UMS won't play 4k video.
Nobody nothing ?
If you still want use this old default renderer, try to add these lines into it and it should trande them fine
Or even better, you should go in the UMS "General Configuration" tab and select the Samsung 9 Series as the default renderer and select "Force default renderer".
After that, restart UMS and your issue should be solved.
It should solve your issue and improve your video streaming quality, bandwidth use and formats support.
As a side note, you are using a Java 32-bit on your Win10 64-bit OS, and weirdly, UMS is using the FFmpeg 32-bit build and not the FFmpeg 64-bit build as it should.
Enjoy
CBRVideoBitrate = -1
CustomFFmpegOptions = -b:v 8000k
Enjoy
Hi,Sami32 wrote: ↑Thu Aug 10, 2017 4:29 am Hi,
If you still want use this old default renderer, try to add these lines into it and it should trande them fineOr even better, you should go in the UMS "General Configuration" tab and select the Samsung 9 Series as the default renderer and select "Force default renderer".Code: Select all
CBRVideoBitrate = -1 CustomFFmpegOptions = -b:v 8000k
Enjoy![]()
Thank you for the answer. I made the settings you said below and set the defauld render to Samsung 9 Series and check the Force default render.
Now the 2160p videos are running but i can't skip forward the videos and the subtitle don't work anymore.
Please, consider post a new log each time, thanks.
I should be able to understand what happen with subtitles from your new log.
Search is not correctly implemented into UMS code, so for now you cannot expect it, and more specificly with Samsung, with transcoded videos.
I just returned the KU6072 back and i bought the new model 43MU6102. Same problem with playing 4k videos, only if i go to NO TRANSCODING folder and choose No transcoding (Sub) works with subtitle on.
It's ok if i run the 4k videos that way ?
As long as you like, it's fine
But if it was working correctly, you shouldn't have to go through these steps.
Btw, if you could post a new trace log with your new TV, it should make us able to create or adapt a renderer for your TV
I think i have fixed the 4K and search issues, so if you are interested to test it...
Hi,Sami32 wrote: ↑Tue Aug 15, 2017 11:44 pm Hi,
As long as you like, it's fine![]()
Btw, if you could post a new trace log with your new TV, it should make us able to create or adapt a renderer for your TV![]()
You can find attached the debug files. So the TV is 43MU6102. When i try to play 4k files, like Lucy movie i see the next problems :
1. The movie is'nt 4k quality, i think it's downscaled.
2. My ASUS ROG fan starts to work full rotations.
2. I can't skip even 10 second from the movie (so no skip available).
3. The subtitle appears twice (one behind another).
- (121.7 KiB) Downloaded 397 times
I'm interested to test it for sure.
OK, so you can try it, but it will take effect only if you do a clean install:
https://we.tl/4TimZnmBPS
